Butch Harley
I put NOS on the front what a difference!!! Craig 516-485-1935
I started using DOT5 silicone fluid 40+ years ago, and haven't looked back. My Charger R/T has had the same silicone fluid in it for all of that time with no issues. I have it in my old Mopars, boat trailers (surge brakes) and will be fill my wife's TR6 system with DOT5 as I finish that up.This all is the reason that I switched to silicone brake fluid. Regular DOT 4 absorbs water/moisture and then leaking and destroying paint. But, it's your car.
Most of us just LOOK WAY AHEAD of where we're going. Know how the car handles. Prepare for either a Ditch or a Pole. NOT the car ahead of us IF we have to "Lose it"This is becoming a long and expensive saga. Started out with noticing stopping power had gotten really sluggish in the car that had 100% of the brake system replaced 20 years ago. Just about the only used item was a booster I picked up. I installed brakes from the Praise Dyno Brake outfit back then which may or may not have become Muscle Car Brakes.
From a vacuum test, that I now suspect of being a bogus test method, I thought the booster had gone bad. I had the booster rebuilt by Harmon and reinstalled and no improvement.
Finally looked in brake master and the rear bowl was clear but the back bowl was brown, rusty mud. Tried to clean it out and the ports had been blocked to the front so no front brakes at all. Bought a new casting, correct style master and installed it after bench bleeding. Flushed the lines, got good clean fluid at all wheel cylinders and no leaks and firm pedal. Adjusted all wheels. Better breaking but still feels weak, especially compared to my 66 Satellite with the same 11” brakes, but no PB, and it stops very, very well. But I have no idea what brake shoes the PO put on it.
All lines are new, hoses were replaced, wheel cylinders were replaced. The Praise Dyno linings got roasted back 20 years ago due to not enough return of the Master Cylinder push rod. After figuring that out and adjusting I found some of the shoes were cracked. Praise Dyno said it wouldn’t hurt anything but now I’m not so sure.
So my next step would seem to be to try some new 11” shoes, but what type and brand? This is a cruiser and doesn’t get any severe use. I want a good shoe that works well cold and warm and I’m not sure if that should be organic or ceramics at this point.
Any suggestions?
Only car I have in my fleet that came with drum brakes I swapped to 11.75 discs, I have the stock drums spindles everything sitting in my storage... Anyone who buys it wants it stock they are welcome to swap it back... I drive my stuff... There are lots of stupid people on the road especially here in California, but I travel enough to know we haven't cornered the market on shitty drivers...Most of us just LOOK WAY AHEAD of where we're going. Know how the car handles. Prepare for either a Ditch or a Pole. NOT the car ahead of us IF we have to "Lose it"
Problem with changing out OEM stuff on a rare car is the PURISTS as myself who WON'T buy it if ya ever must sell it. Id DEFINITELY keep the Original parts.
And for the price of a replacement grill & header panel you could have disc brakes... But hey, you do you....My Bee’s factory 11” brakes worked great at lower speeds, but as Runcharger stated, they totally suck above 70 in that they get hot and fade away around 40, then they are “2-footers”. A few years ago I installed a set of 11” ceramic/carbon shoes but I have not done a high speed panic test yet. I’ll post the results when I do. There’s plenty of deer willing to provide the opportunity around here.
On this car ( probably 1 of 1, all numbers matching, original paint) I keep all mods stock appearing. So discs not an option. On my 67 GTX clone project, anything goes. It’s getting Cordoba cop car discs.And for the price of a replacement grill & header panel you could have disc brakes... But hey, you do you....
So it doesn't get driven.... Cause if it does I would swap the brakes & keep the stock parts....On this car ( probably 1 of 1, all numbers matching, original paint) I keep all mods stock appearing. So discs not an option. On my 67 GTX clone project, anything goes. It’s getting Cordoba cop car discs.
I was used to really long stopping distances. The car stopped well compared to my daily driver.I have a 68 GTX that I got from another member. It has 11” drums and manual master cylinder. For him, it had great brakes. For me, I didn’t care for having to use both feet to get it to stop. I added a brake booster that helped, but not as much as I had hoped for. Then I installed a Granetelli vacuum booster. Now I have a brake system that performs as well as a modern vehicle.
The brakes stopped the car for 130k miles. I drove the hell out of it. Discs really not needed.So it doesn't get driven.... Cause if it does I would swap the brakes & keep the stock parts....
Similar situation in central PA with the white tailed deer. When I used to drive that drum brake GTX to the Chrysler Nationals, with an early morning start, I'd detour through downtown, rather than expose myself to deer crossing the road by my development. I have power discs in the current car, but I still follow the same practice.Plenty of idiot drivers here, but biggest threat are deer, elk, and moose. Greatly reduced risk if you avoid dusk and dawn driving. Which in the summer, is like 4AM and 10pm.
