Can a 69 b body P.S. column swap into a 67 b body?
Moparrush
4:41 PM
San antonio
As title says I have found a decent 69 b body steering column with floor shift and power steering. Want to put it into a 67 coronet with power steering. Is this a direct swap? Thanks ahead for replies.
Also what’s the 69 b body column worth in good shape?
I swapped a 69 Charger steering column into my 67 Belvedere, so I would answer yes to your question. It was almost 30 years ago but I don't recall any issues. We swapped columns because he wanted auto and I was looking to go 4-speed, and both columns were for power steering with original black paint.
67-69 .... should be interchangeable might be minor difference but nothing that won't work
67 column is a one year only. This was the first year for a collapsible column. If your car is auto trans the reverse light switch is either on the bottom or lower end of the column (column shift) or on the floor shift mechanism under the console (I believe) for a console shifted trans application. In 68 and up the switch was moved to the transmission. It's a minor detail but I'm not sure how anul you are to being correct. I'm not familiar with the 4spd trans but probably similar. So yes can be used but not entirely correct. This is, presumably you have a 67 auto trans. Good luck with it.
