1970 Roadrunner parking brake cable with rear disk conversion
jeepme79
New Member
7:16 PM
Iowa
Hi All,
I recently installed the MBM rear disk brake conversion on my 70 RR and it appears the factory parking brake cables aren't compatible. Any ideas on a good source for replacement cables?
Call MBM. **Note** Due to the wide variety of vehicles that the 8 3/4" rear end is used in, there is no single length e-brake cable solution which will work universally with this kit. MBM overcomes this problem by offering a variety of emergency brake cable sizes for seperate purchase, allowing you to taylor fit it to your application. Also available in a standard performance performance kit.
MBM wasn't any help since I'm not a reseller. The kit did come with a bare cable and a couple crimp on stops, but I'm looking for something a little stronger or more stock.
I am a retail customer, can I buy parts directly from MBM?​
No, sorry but MBM only sells to businesses. If you are a retail customer and would like to purchase MBM products then please visit www.piratejack.net.
