Rear end question
VicL
2:04 PM
Franklin, TN
I just picked up a car that was originally a 1969 sport satellite convertible. I wanted to determine if it has a Sure Grip or open rear end. I jacked the back of the car up knowing that if I turn one tire and the other turns in the same direction it's a sure grip and if the other turns in the opposite direction it would be an open rear end. If I turn either Tire the other Tire does absolutely nothing but both tires turn the drive shaft. I've not come across this before. Any help or suggestions would be appreciated
Put it is park so the drive shaft does not turn and then see what it does. Pretty sure its an open diff.
Sounds like a one wheel peel with tight brakes.
Non SG
SG will turn both the same way.
Could be a broke SG but my bet is non.
Um, it wont move if you do that.
On the rear?
Usually a limited slip will pull the other wheel with it through some friction, even.
A non- LS will not, but the friction may hold the other wheel.
If you want to be sure, you can pull the chunk and look.
OK, then.
Glad the mystery is solved.
Yes mystery solved. I appreciate everyone's response. This seems to be a great forum.
Funny I was thinking the same thing but I actually just tried it and in park the wheels turn opposite. Obviously it's an open rear end
Exactly. Glad you figured it out.
I used to be on board with lift the rear, wheels turn opposite = open, or wheels turn the same = SG. As you have found, different internal tolerances can make it hard to determine. but, if you lift one wheel off of the ground and can turn the wheel/driveshaft, it is an open carrier. If you cannot turn the wheel/driveshaft it has a SG.
Looks like you‘re new here. Welcome!
You can introduce yourself in our thread called Welcome Wagon if you want
So what is it now? Kim
