Anodized coating removal
dan juhasz
10:33 PM
Whiting NJ
I googled and read about methods, most popular hits was for ez off oven cleaner (yellow can) . Second method that was popular was lye cut with water but no specific instructions.
What is the best method that you guys have used?
I use the Easy Off. Soak, scrub with a scotch bright, rinse.
The Heavy Duty in the yellow can works just fine, just bought some a month ago.
Easy Off is a real pain and can damage aluminum pretty seriously. What I’ve been using is Lye for cleaning drains, etc. It works quickly (20-30 minutes). You need a pan to soak the part in. A pvc tube works fine for long trim or possibly a 5 gallon bucket. I have a sheet metal pan about 4’x1’x6” for some pieces. I use 12 - 16 teaspoons of lye per gallon of water, typically 12. Don’t leave the parts in too long, even some light anodizing still showing is not typically a problem as it is usually so degraded that it sands right off. Typically, after washing you have a smooth surface while Easy Off will erode, pit and scar up the surface in worse cases to where you have to start sanding with 120 or 180 sometimes. Depending on the amount it can be flushed as essentially it’s drain cleaner.
Can you elaborate
Back when I was racing we used -16 braided upper radiator hoses on our cars.
But I disliked the red and blue anodized finishes on the hose ends. The guy I bought my parts from told me to remove it with laquer thinner... voila it worked.
Maybe todays anodizing is different I dunno but it worked for me.
I don't think Easy Off damages aluminum. I've used it dozens of times to remove colored anodizing and it's never damaged anything. Sometimes, depending on the type of ano, you will get some black smut residue, but that just polishes off with some fine-grit sandpaper or 000 steel wool.
That said, I only needed to soak parts in Easy Off for several minutes, not several days...
Here are some vintage RC car wheels I deanodized to remove the dull gold anodize, followed by polishing, this takes you to that stage of the process. Just some of many, many parts I've deanodized over the years.
"Red Tide": Lucas Agitator Pro 10 Restoration - Page 2 - RC10Talk - The Net's Largest Vintage R/C Community
I used Easy Off for the grill trim on my '68 Charger. I cleaned it up with a Scotch Brite and then sent it out with the rest of the trim and had it polished
