fullmetaljacket
Yes. Race Hemi orange. Just like the steel 6 quart #971 deep sump pan on there now. No decals.you going to paint it engine color ?
Do you check those welded pans for leaks using a light solvent before sticking it on the car?These aluminum oil pans are not as light as one would think. Contrarily, the baffles, dams and trap doors are relatively light. It is the inner and outer weld beads to Frankenstein all the break formed panels together that are partly the culprits. The pan rail such as this one with a 3/8" thickness also contributes to the weight which in this particular case is 7lbs dry. The stamped steel one will be weighed to make comparisons sometime soon. I think it will be lighter even with the same oil capacity.
I must say it is a very well made piece as one can see. I would guess oil cooling for street driving would be improved by a small amount. Obviously, the dams and doors keep the oil pumps tummy nice and full.
Identification decals will be removed to protect the not-so-innocent.
Yes first and foremost. A solvent like gasoline or just plain water will test the seams. Also it will reveal the true oil capacity of the sump and help with adjusting the dip stick depth.Do you check those welded pans for leaks using a light solvent before sticking it on the car?
Never did like using gasoline since it's so flammable but at least you can throw it into the mower once you're done with itYes first and foremost. A solvent like gasoline or just plain water will test the seams. Also it will reveal the true oil capacity of the sump and help with adjusting the dip stick depth.
Secondly will be the pick up height from the sump floor.
The side pan rails are super straight and thick to make good compression, even though the hardware doesn't really need that much tightening. Aluminum 2024-T6 bolts and washers.
.........................or finish cleaning parts. I'll most likely use water anyways. gasoline is getting a little pricey these days now.Never did like using gasoline since it's so flammable but at least you can throw it into the mower once you're done with it![]()
I got pretty decent with welding some years back including MIG and TIG but just don't do much anymore so every time I light up, it's like I have to 'relearn' it all again real quick. Seems like stick is the easiest to relearn since that's what I did most lol..........................or finish cleaning parts. I'll most likely use water anyways. gasoline is getting a little pricey these days now.
I also have links to a military grade welding guy that can seam close anything. He's been welding all of my stuff.
Yeah, I've never taken the steps to learn TIG or MIG. I'm probably most afraid of what I might build if I do know the craft.LOL.I got pretty decent with welding some years back including MIG and TIG but just don't do much anymore so every time I light up, it's like I have to 'relearn' it all again real quick. Seems like stick is the easiest to relearn since that's what I did most lol.
Yup it is an art imo too. I got good then bad then good again and who knows how I am now lol. MIG is easy but TIG not so much. Might be because I never really learned how to gas weld or practiced it. I think it's very similar. Struck up my first stick 'arc' in 69 and got pretty decent with it to the point I could stick weld the trim holes on a car body without warpage or burning the hole bigger and that was using an old Lincoln 225 cracker box using an extra long positive lead. The machine I have now lets me do that with ease. Just wish I had this thing many years ago. It's outdated now but don't care except for it's big and takes up too much room.Yeah, I've never taken the steps to learn TIG or MIG. I'm probably most afraid of what I might build if I do know the craft.LOL.
Welding is an art in itself.
Transmission fluid will detect any and all potential leaks and not risk burning the house down..A solvent like gasoline or just plain water
Water it is. Thanks fellas.
Great ideas. Thanks guys.My pan has been hit and cracked enough times I've learned. Let it set with liquid at least 24 hrs on dry paper towel. Ask me how I know. And yes RTV will seal small cracks when it's on the car. Better yet? This last go round it had been hit pretty good. We welded what we could see. Then used soapy water on the outside. And shop air on the inside. Found a few small cracks/holes. Much quicker than waiting the 24 hours.
D. You're deep undercover. LOL.Stefs fabricates beautiful pans. Fortunately mines covered with a daiper so no one see it.
You could paint the bottom 2-3 inches of the sump the same black that’s on your k member so it disappears under the car instead of looking like a neon sign hanging down.D. You're deep undercover. LOL.
Ironically, mine will be out in the open in splendid race Hemi orange. Who am I fooling? LOL.
