Air Conditioning Templates?
dodge68charger
11:34 AM
Washington
Would Like To Put Air Conditioning Into My 69 Superbee.
The Car Did Not Come Factory With A/C
and I Don't Really Want To Put The
'Under Dash' Unit In If I Don't Have To.
Heard Good Things About Classic Auto Air
Is There a Template To Cut Out The Firewall/Dash Holes That Anyone Knows Of To Use The Factory Style System?
Thank You
None that I know of. I thought Classic had a template for their systems? If not, then you might have to get creative
I made a cardboard template from a factory AC unit. The problem is locating the holes accurately against a non-AC firewall. You can get close using photos from web using the fire wall suppliers pics but I’d like to be more accurate. The best case scenario would be to find a AC car without an engine you could measure and find common reference points.
I’m going to take some dimensions / make a template this weekend if it works out. I tried taking measurements on a car with the a/c unit installed and I wasn’t comfortable hacking into my firewall with those dimensions. The car I’m looking at this weekend is an a/c car with no a/c unit installed just a bare firewall. I’ll let you know if it happens.
Non A/C
A/C
MM1979 - 1968-70 Dodge, Plymouth B-Body; Firewall Panel; with AC; EDP Coated
Is this a clinker? I do not know if B bodies are like A bodies, but for A bodies, aftermarket A/C units are for non A/C cars, because the firewalls are different. You would have to make a filler for the unit if it was a factory A/C car. So before you go copying an A/C car, you should find out. I'm thinking that they are different.
Isn't there "divits" where holes are to be made for AC? I know my '62 has them on the firewall.
i bought the classics system and it came with a templet for the fire wall . i cut my dash in my 69 runner and made it look factory BUT the air flow is not quit enough to me.
if you are adding factory a/c them make your templet . if you are using an aftermarket system go to there web site down load the install instructions witch will have the templet for there system.
Haven't seen another mention of it, are the firewalls different? A/C-NON A/C?
That is what I was getting at. Why would you copy or make a template from a factory A/C car. The aftermarket one is probably for a non A/C car.
you are right mine was a non a/c car and the holes are different.
Ok, I’ve made a template for locating the holes for installing a factory air conditioning system in a non-ac car. I found an ac firewall and made the template from the backside of the firewall. This is not to be confused with an after market system. There are some common reference points so it will be accurate. I plan on making it out of vinyl with the open holes where the cuts need to be. The heater core holes where the original heater core holes will have to be flush patched prior to cutting the new holes. I’ll send pic’s when I can.
Ok, I made a template from a donor firewall and used common reference points. I made the template from poster board and cut reliefs slits to form the compound curves by the transmission hump. It took many adjustments and tweaking to get it right. My vinyl template idea was not good, too flexible. After a bit of clean up up it turned out ok.
