Moms68
Anyone have any experience with REM polishing of a hydraulic flat tappet cam and lifters prior to engine start up?
According to the shop that does it (New England Gear), and someone locally who has used their services, the REM polishing process actually replicates the break in by making the mating surfaces extremely smooth. Mostly used for race car applications where break in time is not always in the cards.I have no experience with REM on camshafts, but it would seem to me it could be very problematic, in that the break in/burnishing phase is bypassed and if something is not 100% perfect, lobe wipeout is not delayed. Now if you wanted to ask about cyro, DLC, etc those methods make a lot of sense here in many ways.
What is your expected gain with REM in this application?
It's a decent question. It begs the next question.. does a somewhat rough finish on the end of the lifter promote spinning in the initial mating process, or break- in if you will
The question could also be if the cam had a non-smooth sacrificial surface layer to help promote break-in lifter rotation.
