New 69 Charger Data decode
Installed a Suregrip while I was in there.
AC parts are starting to get rebuilt.
I want to redo the instrument cluster. But I want to drive it awhile!
The car has obviously been repainted once and the paints either faded or the wrong paint was used. It’s a long way from T5 copper.
Bought this car today in Oregon. Haven’t got it home yet but will post photos when I get it here.
regarding this dataplate, a couple codes I don’t see in the book:
R11=AM radio
V1X (?) = Black Vinyl Roof
26 = Rad size
H51 = AC
L31 = Hood turn lamps
M21 = Roof Drip Moldings
M31 = Belt moldings
N88 = cruise control
P31 = Power Windows
A01 = light package
A41 = White hat special
B51 = Power Brakes
C21 = Front Center armrest
C55 = ?
G33 = LH mirror
T5 = paint codes
C5X = Black seat, carpet and door panels
X9 =?
E63 = 383 4-bbl
D32 = Auto trans
H9G =
Thanks in advance for any ideas !
Hello to all
I look that there are 2 fender tags for a 1969 dodge chargers once like the mate Mheiron and other like this:
The last one its the normally from 1969….
The first one have the color codes with 2 digits only, 6 rows instead 5…. Where can I decode the first ones? Web page?
Thanks and best regards
Hello to all
This picture represents the format and layout used at plants other than the Jefferson and Lynch Road plants beginning in 1970.
It is not the format used for '69 Chargers at either the Hamtramck or St. Louis plant.
There are numerous 69 tag decoders on line. Some are mostly accurate some are not so be careful which ones you use.
I see - I thought we were going to look at your car's tag.
In the actual tag shown (2 characters/2 positions for paint), it is normal for 1969. The "missing" first character of the paint code (xT5) is somewhat irrelevant as it refers to the model-year that particular color was first developed for (example below). The 3-digit paint/4-digit interior tag coding is as @69Coronetrt states - not until 1970; that decoder you show really isn't appropriate for 1969, and prior to '69, the tags are completely different.
If this tag/car had more options, there would be a 6th (top) line, but 5 lines was enough to code how this car was to be built. And if 6 lines aren't enough for a car's option codes (the ones that even GO on these tags), a second tag is added with the codes that didn't fit on the first tag.
The tag showed its from St Louis plant “G”
Thank you
Yes the online decoders for 69 and onwards dont work with this type of fender tag. Do you ones that work correctly??
Im learning about fender tags, window stickers and broadcast sheet
...ones that work correctly??
Unfortunately, I don't. I basically do it manually from numerous lists and charts that I've saved from Many locations/people.
You can probably 'make' that one work with moderate accuracy. The codes are mostly the same between '69 and '70, but some tag positions are moved. Kind of like this:
I'd say go ahead and try entering something like this (below) and see how it works? You kind of know what you're expecting, so experiment a bit. I'd try that one you show, but I don't know where it's from.
Great job, thank you!!!
Yes I do it manually too
