carb spacer
hacksaw
12:43 AM
hopewell PA
ok...I will be running the stock in line 2x4bbl intake and carbs i need to bring the carbs up on the mill. Don't really want to use the aftermarket spacers because it looks like .. so what is out there that i can put under the early 60's carters to give me 3/4 to 1 inch of room without looking like its patchwork. I can't remember what was used stock.... thanks
Curious why you need to raise the carbs?
I do not remember inline 4 barrels, except Hemi. Doesn't look like stock linkage, but, I would say elevate the linkage.
linkage clearence and i want to add some volume to the intake.
FYI....by adding volume to the intake manifold below the carb, will REDUCE the mixture VELOCITY by creating a pressure drop as the mixture expands.....and a slower mixture velocity can lead to uneven or non uniform cylinder filling. The idea is to keep the velocity high from the carb to the intake valve......just thought you might like to know the reason......
BOB RENTON
Maybe try some phenolic spacers
kinda what im looking for. don't want the metal ones...i can find them for the newer carbs or the 8 bolt holes. if i remember the stock ones was 3/8 thick. that would be perfict.
BOB RENTON
the set up in the pic ain't what im running. that is from the 58 350. just a pic to give an idea what im doing.
Fits Holley Carter AFB Carb Phenolic Insulator Spacer 4 Barrel Riser 1/2" Kit | eBay
Fits Holley Carter AFB Phenolic Insulator Spacer 4 Barrel Heat Soak Carb Riser | eBay
I am pretty sure that carb set up uses the inboard set of mounting holes. Holley spacer [ & some carter/Edel ] would not fit unless they have the dual pattern mounting holes.
Another possibility is TQ or Quadrajet spacer, which is the same bolt pattern as the inboard bolt pattern on the AFBs. You would need to check that the underside of the carb & intake seals up ok.
ya it dose use the inboard holes. was lookin for something that looked stock. got it figured out tho...
