Adjust rockers to ..?
kaj750
2:10 AM
Fresno, CA
I keep reading that I should check the adjustment of my rockers, when installed, but no mention of what I'm adjusting to.
I'm installing new lifters because I had one fail.
Once I put the rocker assembly back on, what specs am I looking to adjust? The lifters are hydraulic, so what's left?
My rockers do have a lock nut on top of a threaded portion that the push rod goes into.
I can't find any information on why these are adjustable nor how.
Thanks, in advance!
I was always told to adjust to 0 lash and then add 1 1/4 to 1 1/2 turn of preload.
That is a fairly safe range... It kinda depends on how you use the engine... street car, lots of normal driving adding a little extra preload will keeps things quieter... But if your hitting redline regularly we use to set 1/2-3/4 turn past zero lash so the lifters are less prone to pumping up & holding a valve open...
My 451 stroker is at 1 turn currently and still has some lifter ticking on a few valves. I plan to give them all another 1/4 turn. I was easing in to it for a good cam break in.
I'm using the old Mopar performance iron ductile rockers and the adjustment is tedious.
100% Street car. Rarely sees 5k RPM. Prefer quieter > higher RPM racey motor.
Thanks for the tips, guys. I will do this as soon as the new lifters are in and report back.
Bleed a tappet down, count turns from zero lash to bottom of the tappet, then back off half way.
There’s an old Direct Connection valve lash adjustment chart & I follow that. Rotate 90 degrees, set one intake and one exhaust rocker valve lash and repeat. I run 1/2-full turn in after zero lash. So….following the DC chart, I loosen an adjustment nut way loose. I turn the ball/stud in/out with a screwdriver while I twirl the pushrod between my fingers of my left hand. You can “feel” right at the point where you get resistance to twirling the pushrod. That is “zero lash”. Now turn the adjuster screw in another 1/2-full turn & lock it down with the nut. 1 intake & 1 exhaust at a time on different cylinders per the chart. Readjust maybe ever other time you change spark plugs or every 20,000 miles or something (?)
Most cam and lifter companies recommend aprox .040 preload. Most adjuster screws are 3/8 fine thread. One turn is right about .040. So zero lash and one turn.
www.compcams.com
Section I. Setting pre-load with ADJUSTABLE ROCKER ARMS
Turn the engine in the normal direction of rotation. Start with cylinder number one (1). When the
exhaust valve begins to move, adjust the intake valve to the correct pre-load. To reach zero, take
the pushrod between your finger tips and move it up and down while you tighten the rocker arm.
Once you feel the pushrod has no more vertical slack, you are at zero pre-load. Make sure the
pushrod is in the lifter and the rocker arm seat when making valve adjustments. As stated before,
the recommended setting is .045" or 1 turn of the wrench past zero. Now, you can move on to the
exhaust valve on the same cylinder. Begin by rotating the engine over again until the intake valve
reaches maximum lift and is almost all the way back down. Then set exhaust valve using the same
method as the intake (.045" or 1 turn of the wrench past zero). Continue adjusting the valves on
each cylinder in this manner until all valves are adjusted
Sounds simple enough.
I may have a bent pushrod (unless the end isn't machined correctly). Maybe my problem, seeing how the lifters look fine upon initial inspection.
Most FT hyd lifters have about 0.150 -0.180" travel of the plunger when fully bled down. You can adjust anywhere within this range, it makes no difference to the actual operation of the lifter.
If you adjust so that the p'rod cup is just below the circlip, very little lifter pump up would be needed to pop the circlip out.....which would be caused by over revving or missed gear shift. So better to adjust the lifter with prod cup down 040-060" if your valvetrain allows for that adjustment.
Anti pump lifters use a very strong circlip, not the paper clip variety.
Once removed, should the lifters move at all when pushed on, with a rod? I assume the lifters that were on any partially open valve should have less oil and so allow movement, correct?
Just asking because I noticed some had play and some didn't.
Put the lifter in a paint cap full of oil, use a push rod in a drill press and see if you can pump it hard... if not take it apart, clean it, reassemble and try again.
---------------------------------------------------this ^^^^^^^^^^^^^^^^^^
Very often, hand pressure will NOT collapse a pumped up lifter. You have to put the lifter in a vise with a bolt or similar in the prod cup & slowly close the vise. Slowly, because you do not want to bulge the lifter body.
Because the adjusters are in-line with the pushrod it is fairly accurate to convert the adjuster Threads Per Inch (TPI) into preload.
Usually the adjusters are either 20 or 24 TPI, so one turn (thread) is 1/20 or 1/24 of an inch (0.050" or 0.04167")
Most of the common hydraulic lifters recommend about 0.040" to 0.060" pre-load, so one turn will work for either thread pitch.
FWIW, On a stud mount rocker adjustment, the rocker ratio needs to be multiplied to the TPI distance because the adjustment is at the pivot, not the pushrod.
An example might be 1/2 turn pre-load on a 20 TPI rocker stud with a 1.5:1 ratio would be 0.0375" pre-load.
Just saying that answers in percent of a turn need to also contain the adjuster TPI, where the adjuster located, and the rocker ratio if the adjuster is not at the pushrod end.
I guess I'll go with "close enough" seeing how it sounds like there is some wiggle room, given all the different answers. They are pretty much close to being the same.
I will err on the side of more preload to keep things quiet seeing how I don't race the car.
More preload is not going to make the lifter noisier.....or quieter. The lifter has preload, not for noise control, but to cover the range of tolerances that you get in the valve train. Example, you fit a cam with more lobe lift; the cam's base circle is reduced, meaning the prod sits lower.
