57 Fargo
First of all I’m primarily a C body and A body guy, so be gentle!
I’m working on a ‘66 Charger for a friend, getting things working. None of the gauges work, no 5 volts out of the fuel gauge, I hooked up a later 5 volt regulator and got that going but still nothing. I did try grounding sending unit wires and nothing moves, finally I checked the resistance of the gauges from the 5v post to the sender post and they are all open. I’m assuming the original regulator stuck shut and cooked gauges with 12 volts. Am I missing anything?
Also someone has removed the power pack for the lighting, are they available or search for a used one?
Thanks in advance.
Thanks in advance.
