Pinion Yokes - What to Use
Charlie Brown
3:24 AM
Vars, Ontario, Canada
I'll be having a new driveshaft made for my TKX conversion. The yoke on my diff is currently a 7260 small yoke. Engine is a 426W in the range of 450 hp / 450 torque. 64 Dodge is the car. Is there a good reason to upgrade to a 7290 or 1310 yoke or will the 7260 handle what I have. Thanks, Charlie.
Well, I would want a solid u-joint . Not sure they make a small one, but they do make the large one. I just wouldn't want a greasable u-joint.
If your buying a new driveshaft made go 7290 on driveshaft and use a combination u-joint 7290/7260 to mate to rear yoke. If change HP you'll have a strong driveshaft.
I agree with Fran,
7290/7260
I have used the conversion joints on many cars.Even drag racing with slicks.30 years, never a failure.
The photo is of my 65 Belvedere 451 B stroker with a Tremec TKO
Stick shift with big block torque? Go as big as practical.
2nd on Frans answer. (Or more).
Assuming 8 3/4. What # housing? (Spacer or crush sleeve?)
Why not just go 1350 and be done with it?
If it was a race car with a stick and twelve inch slicks, that's what I'd recommend too. I've got a four inch aluminum shaft with billet yokes and 1350s on both ends, in my 14"slick transbrake car.
"Spirited" street driving doesn't need it. Unnecessary expense.
I guess that no one here has ever twisted a greasable u-joint to destruction. It's your car, it will probably be fine. Not for my car.
Currently, I have a 741 case (3.55 w / cone style LSD) and a 742 case (3.23 w / clutch style LSD). Both have small yoke. I do have a 3.55 gear set for the 742, which I would have to swap to use with current trans setup.
STRANGE ENGINEERING……
Great People & Phenomenal Parts !!!
Mopar2ya!
Then Fran's #3 is the answer I would go with.
Regarding a greasable joint..... just make sure the joint is installed with the zerk in compression under power.
Yes, solid is preferred, but if greased combo is all that's available......?
So, the solid vs greaseable joint discussion, is the problem where the zerk is located on the joint or the fact the joint is also completely cross drilled?
Seems like a cross drilled joint could be very easily greased without the zerk accommodation if the zerk was located in the end cap in 4 or say 2 opposite caps, for balance, and just lube thru those fittings, having best of both worlds? Can't see a zerk in the center of a cap weakening it much if any.
I think the zerk is located where it can be greased without disassembly. Kinda hard to do in the center.
And I much prefer the solid joints too. How many times is a zerk-fitted u-joint routinely greased?
My suggestion above has nothing to do with the inaccessible center of the u joint.
I'm talking about the center of the end cap(s) and very easily greased with no disassembly.
If one wanted a true solid uncrossed drilled u joint, then use four zerk fitted caps
U-joints are made with ability to grease through a cup. The grease gun need to have the tip like a ball with a hole for the grease to come out. Manufacturers don't seem to make them widely available or I haven't looked that's true. If I can find a pic I'll post it right the search is buffering WTF!
Picture with regular zerk and ball fitting, you need round tip on grease gun.gf.JPG
Why the round tip?
Looks like a conventional zerk grease fitting installed in the cap?
Most likely never. For the average guy or gal. If diversify comes in play, game over..
