Thunderdan
I like this build. I have a '78 Monaco police car (A38/E86) with the factory 2.71 9-1/4 rear that I am considering a similar build for on the factory 440 and the stroker is the easiest way to reliably do this with low stress on the configuration. Aside from the relatively mild cam you spec'd out (which helps torque and drivability), the factory stamped rockers - especially if higher mileage -are rarely the 1.5 ratio they are advertised as and are often down to 1.4 or even 1.35 or so making the cam even milder that spec'd. I'd suggest calling Howards or Hughes to get a recommendation on the cam to maximize power while keeping drivability up there.
Why someone suggested a 500 stroker based on a 400 block when a 440 will easily handle the power at the moderate RPM you are planning AND you already have the 440 at the machine shop and the parts on the way makes very little sense. Excited for this build and definitely keep us posted on how it unfolds.
