Gen 2 Hemi valve spring tool
RVW
9:01 PM
Richland MI
Does anyone make a tool to replace/check Valve springs for a gen 2 Hemi with the engine in the car?
Used a KD and made an extra hook leg that would lock up when compressing spring. If you don't make that extra leg forget it. There are 2 legs on KD a long and a shorter one you need to add a long on the short side. And I still needed push on the compresser and have a magnet ready to get the keepers out. PITA
I have one from Buxton Engineering. Pricey, but nice. You can check and change springs in the vehicle. Mine is for the RBRE rocker system. You can purchase different bases individually for many others different kinds of engines as well that adapts to their kit. You would think for the money though it would come in it's own nice storage case, but it doesn't. So, I made one with our Sta-pak packaging machine at work to keep everything separated and protected.
For a wedge, not a Hemi; but I just made this last weekend starting from a stock stamped steel rocker arm….
I built this valve spring compressor recently. Based it off of some pictures a Buddy sent me.
I have used both the Mancini tool and Richard Trouts tool to change hemi valve springs with the engine in the car. It was tedious but got the job done. Like Fran said-PITA.
