Low Profile Intake on 440 in 1966 Coronet
I have a 67 wagon w/440. Performer RPM with a Holley 3310-1[ 780 vac sec] carb. Filter assembly is a MP one. Fits under the hood with no issues. This filter unit won't work with an AVS/AFB unless you put a spacer between which will get you hood clearance issues. The base only works for center hung bowl Holley's due to its contour. There are low profile units that will fit the AFB/AVS and some others. You'll need to check around. The inner portion of the base, where it drops over the carb, looks like it was formed over a big bagel/doughnut. Big, dropped circle.
Let’s clear a few things up.
Here are the intake heights relative to the 178:
CH4B - +0.4”
Performer - +0.5”
HD. - +0.9”
Torker - +0.9”
6-Pack. - 1.4”
Indy 440-2D. - +1.6”
Perf. RPM. - +1.6”
They all clear the hood. You can also make all of these work with the factory air cleaner. The level of effort and creativity to make it work goes up considerably the taller the intake.
Great data, thanks for sharing!
I have used a lot of Isky FT cams, no failures.
Lifters: find some factory lifters & have them re-faced.
Hi Geoff
I have not reused lifters.
The engine I have has been off the road at least 4 years, probably longer. I never heard it run.
I have a set of lifters that came on the engine. How would I know if they are bad or good and could be reused after reface? Thanks, Ben
Hi Geoff
Look for any indication of a wear mark straight across the face. That indicates it wasn't turning in the lifter bore like it's supposed to (HAS to).
Put the lifter on a pane of glass. It should wobble slightly, because the face has a radius. No wobble, no use.
There have been many instances of poor metallurgy, either the cam hardening, or the lifters, causing failures. That's why some are recommending getting known-good lifters re-faced.
IF the lifters have been run on that cam, it's important that the lifter stays on the lobe it's been married to, if you plan on re-using them.
I thought the point of refacing a lifter is so it can marry to a new cam.
What am I not understanding?
Nothing. You've got it. But the idea of refacing the old lifters is to get like new performance out of a known nice hard lifter, so it can be used on any camshaft.
And hopefully they grind them to all the same height
That is why there is 0.150" or more of internal travel inside the lifter, to allow for tolerance variations.
As Doug said, The Street Dominator is the King of Power in the category for performance intake that will fit under the hood, as demonstrated in many dyno shootouts. Which makes no sense when you look at it. Low, flat, heat riser, EGR valve, small ports. It looks like the slowest intake ever. But it is the King.
Street Dominator didn't fit under the hood on my 69 roadrunner 440.
That's kind of a surprise.
I can see that it probably wouldnt work with a stock air grabber system and aircleaner. (The stock airgrabber wouldnt work with a stock 440 intake without rework. No 440 4bbl's in 69 rr's)
Did you try a drop base aircleaner?
