TorRed
- 12:06 PM
- Dec 12, 2023
- The Villages, Florida
First off, I've kind of asked this question in other threads but wanted to try again to get anyone's experience actually building such a motor: 383, either massaged 906 or CNC'd Stealth heads, roller Lunati cam, 231/239 @ .50 535/550 lift, either 3.75 or 4.25 crank for 432 or 489 c.i., stock HP manifolds 2.5" TTI exhaust with Dynomax Ultra Flo mufflers, 4.10 rear with Gear Vendors .78 overdrive, 727 auto & tight 3000 rpm converter, and either stock, Mopar dual-plane M1 or Ede DP4B intake
Thoughts? Would either crank work better given my constraints wanting to appear stocK? Other path would be mostly same parts with stock stroke with custom pistons to get as close to 10to1 compression as possible, but only if it doesn't make sense to stroke it if I'm going with stock HP manifolds and stock height dual plane intake since it's an Airgrabber car.
Thanks in advance,
Jim
Thanks in advance,
Jim
