68 charger front disc brake hoses?
koosh
10:23 PM
CT
Upon acquiring a 68 charger, previous owner installed new front disc brakes he believed were for 74 Duster. Unfortunately the front brake hoses are a bit too short, stressing on the fittings. In order to get longer hoses which will fit both the hard line and the caliper, what would i look for?
Are your caliper’s rear mounted?
If so, Something about 15” long.
Doctor diff sell’s hoses that are spec’s for 1969 camaro with disc brakes for this application. I’ve also ordered for 1969 camaro with disc brakes from rock auto and they fit well when using A body disc brakes on my 69 Belvedere. . They also have the fittings you need.
IF you can find a knowledgable parts guy to help you out at a store, IF the store has the picture book for the brake parts manufacture they sell, you may be able to come up with longer hoses of factory type[ rubber]. In the illustrations of the hoses, they will list them by part number/style/fitting type/ fitting sizes. With that info, they can possibly find you longer units. This is one of the many things I did when working at parts stores so I know it can be done. Just gotta have someone willing to do it and the store needs to have that illustration book.
Auto parts stores around here only hire people from lingerie dept
Yes, calipers are rear mounted…..You’re saying if i look up hoses for a 69 Camaro, they should fit my 74 duster caliperss?
That’s exactly what I’m saying, camaro with disc brakes not drum.
If you don’t like rock auto I’m sure your local store can look it up and provide them too. Or have them cross reference the number from your research from rock auto. I think they have 3 f]different brands. They’re probably all made in the same factory
Rock auto ⬇️
More Information for ACDELCO 18J1798
Here are some photos…current hoses have the standard fitting for coupling with hard line, the other end is like a”block fitting”
View attachment 1827833View attachment 1827834View attachment 1827835View attachment 1827836View attachment 1827837
Yah, that’s no good. I’d prefer to have the inlets at the bottom which you could accomplish by swapping the calipers from side to side. Being that the inlet and bleeder would be at the bottom they may be slightly harder to bleed. Some people get around that buy bleeding them not attached to the caliper mount with a block of wood between the pads and the bleeder facing up. Then reattach to the caliper mounts.
When doing these conversions I specify caliper for 85’ diplomat which can accomplish the inlet at the bottom and the bleeder at the top orientation. But yours are still usable just harder to bleed. I don’t care for the one that have the inlet and bleeder so close to each other
Here’s an example of a diplomat spec caliper. You can see the inlet and bleed opposed to each other.
More Information for RAYBESTOS FRC4108
Rock auto ⬇️
Ordered the above hoses from rock auto, little confused when it comes to the length see attached specs.....I'm hoping the first "axis length " means overall length.....
Axis 1 Length (IN)15.6875
Axis 1 Length (MM)398.4625
Bracket MaterialCorrosion Resistant Steel
ColorBlack Hose
End 1 Fitting MaterialCorrosion Resistant Steel
End 1 Fitting TypeNPT
End 2 Fitting MaterialCorrosion Resistant Steel
End 2 Fitting Type7/16-24
Gasket or Seal IncludedYes
Height (IN)3.03
Jacket MaterialEPDM Rubber
Length (IN)7.12
I suppose I’ll have to bleed the brakes all over again once new hoses installed….
Will i be able to just bleed the fronts? Or have to do all 4 again?
