padam
No, I’m just running the alternator. Still using mechanical water pump and fan.Do you charge between rounds? With something that hits it with serious amps? While running the fan and pump
No good!!No, I’m just running the alternator. Still using mechanical water pump and fan.
NO....you should use it because of its magical powers.....plus it could cause your MSD/ECU to stop working, leading to multiple burnouts when least expected......"I need a new battery for my car.
I have the battery in the trunk and prefer something big and heavy to help with traction.
I used a deep cycle battery before and it worked fine.
Walmart has a big Group 27M with 800 cca.
Does anyone see a reason I shouldn’t use it?"
YES! You shouldn't use it because it is from the evil empire!
That only means that they are made by the same company, but not necessarily to the same standards. Walmart can provide their own specifications for what they want built, and the end result may or may not match other brand names. Optima is made by Clarios (formerly Johnson Controls Inc.) who also build for many other companies including AutoZone, Bosch, Target, Champion, Delphi, O'Reilly's, Diehard, Interstate and CostCo to name a few besides Walmart. If you lined up, say, a group 27 battery from each of those, you might find weight differences due to individual brand specs.Some of the videos I’ve seen show the Walmart batteries are made by the same company as Optima.
If its from the evil empire [w**m**t] then you shouldnt use it, magical powers or not!NO....you should use it because of its magical powers.....plus it could cause your MSD/ECU to stop working, leading to multiple burnouts when least expected......
BOB RENTON
Except on alternate Wednesday or Thursday on the 34th of the month, then their magical poweres are enhanced......do not underrate magical poweres.....they can become awesome....and overwhelming.....???....If its from the evil empire [w**m**t] then you shouldnt use it, magical powers or not!
Use it, you will have a longer starter revolution because there is more battery, if you end up needing it.I need a new battery for my car.
View attachment 1828628View attachment 1828629
You have no power here! Begone, before somebody drops a house on you too!Except on alternate Wednesday or Thursday on the 34th of the month, then their magical poweres are enhanced......do not underrate magical poweres.....they can become awesome....and overwhelming.....???....
BOB RENTON
Is that smoke you noted from doing burnoutsouts or the magical smoke from burning "weed" (tetra hydra cabananol) ??? and inhaling....or as it use to be said: "far out....baby"!!!!!!!.........which smoke do you like???.......I can see that it's from experience that you've been warning about the dangers of tire smoke, Bob.![]()
Funny you should mention that. The picture of the battery I posted first was actually the battery I use in my trailer to power an ac inverter for the lights and stuff. I charged it up and tried to start my car with it after my regular battery wouldn’t take a charge. It checked ok with the tester but wouldn’t crank the engine.What about a 1000cca battery for semi trucks? Plenty of amps, plenty of weight, and stud terminals.
