Trick Flow 727 pan
If the pick up isn't down near the the bottom of the pan it can absolutley suck air.
Hey Doug,
Do you run a filter extension with these? If so, which one? And what gasket do you use?
The Mopar reusable gasket for the 46RH. Same gasket even with freshen ups and filter changes on the racecar, 13 years. Ti made an extension that I believe was 1 3/4" Ebay has billet spacers in 1" and 1 1/2" cheap.
Great Info, Thank you Sir.
