I looked at a 63 2 years ago as a possible driver replacement for my 04 dually. That thing was a turd despite what was advertised. Glad I eyeballed it ahead of time. Scored a 67 Deluxe a year ago that is a driver.
Thank you for the note! Definitely going to remove it then, avoid the risk of burns from the welding.Looking good. Once you remove the front and rear upper windshield surrounds, the two galvanized side supports pop off and the headliner falls out. 1000 times easier than dealing with a standard headliner.
I was wondering how they would have made that lock secure the lid...
Btw- where does a floridan have to go to be on vacation??
This is a GG1 car. I'll be painting the floor pans body color on the inside for sure. Because I plan to drive the car frequently, I'll likely undercoat the bottom.Is the paint code on the fender tag GG1 or LL1. Looks like GG1 to me.
You will have a very nice car.
Our car is GG1. It had factory undercoating over the paint on the underside.This is a GG1 car. I'll be painting the floor pans body color on the inside for sure. Because I plan to drive the car frequently, I'll likely undercoat the bottom.
I see the same on mine in the couple of small areas where the undercoating has come off underneath, green paint visible. My local paint supplier confirmed they have the color blend for 1966 Dodge GG-1. They also offer matching from physical samples, however I think seeing as this will be covered both top and bottom eventually, as long as it is pretty close to the correct color, I am fine with what they have documented.Our car is GG1. It had factory undercoating over the paint on the underside.
If you are going to use the correct match, get the paint formula for 1966. It could be a different mix than 1967 for example.
When we were getting ready to paint our car, the painter had the supplier supply samples of 1967 and 1968. We held them up to the steering column bracket and you could really notice the difference.
Well I hope 1 key goes to the gas flap lockI see the same on mine in the couple of small areas where the undercoating has come off underneath, green paint visible. My local paint supplier confirmed they have the color blend for 1966 Dodge GG-1. They also offer matching from physical samples, however I think seeing as this will be covered both top and bottom eventually, as long as it is pretty close to the correct color, I am fine with what they have documented.
Spent a couple of hours doing some preliminary cleanup in the engine bay removing road grime from the K member and starting to clean up that hardware in preparation for removal a couple of weeks from now. I found the original owner had tucked a magnetic key holder way back on one of the front frame rails. The container was rusted to hell, but the keys were actually in decent shape. Interested to see if I can figure out what they go to.
One key was for the locking gas cap that was in the trunk of the car, or at least I presume so as it says "GAS" on it haha. The keyhole next to the gas flap ended up being a crazy external killswitch gizmo! It was wired into the ignition from what I can tell. Sadly none of the keys I've found so far work with it. I'll probably just leave it there but disconnected until I get around to the bodywork. Better than a 3/4" hole!Well I hope 1 key goes to the gas flap lock![]()
Most of the floor is now removed, now the driver and all 3 passengers can help!The sun shining through the floor makes me think its "Yabba Dabba Do Time"!
