Valve Lash
Tony 69
2:34 AM
North Carolina
This has probably been discussed before but I need a refresher lesson. What is the best measurement to set valve lash on an unknown solid lifter cam? Preferably cold.
I would start at .025". That's a nice number given by many cam manufacturers. I'd say anywhere from .020"-.025" is safe.
Year's ago, for the GM/Corvette 327/300 HP aftermarket cam, the HOT issue, was the Zora-Arcus Dontov 30-30 cam......0.030" cold valve lash both intake and exhaust valves......sounded like a Singer sewing machine, idling at 1100 RPMs.....sounded wonderful and ran extremely well......7000 RPM max......don't remember the duration or lift specs..........just a passing thought.....
BOB RENTON
I'd go .015" with aluminum heads, .020" with iron heads. Lash will grow hot. Loose beats stuff up. A little tight won't hurt anything.
Hot lash for my Hughes STL cam is .010" Intake / .012" Exhaust. I set mine cold at .008" Intake and .010" Exhaust and things have been fine. I have aluminum heads.
If you check a few hot. I'll bet you could tighten it up. You have to work quickly as they cool very quick and change. With my -1's .020" hot is .014"-.015" cold
Update
Finally removed the valley pan and found the lifters are hydraulic. Valve train has been noisy since I got it so I was surprised, especially with roller rockers. The lifters push down pretty easily when going to adjust. I went zero lash plus 1/2 turn but can still push the lifter down by hand. I’m thinking crank the engine over to pump up the lifters and repeat. Does that sound right?
