FOUND '66 Bucket Seat Tracks (maybe '67?)
Voodoo
1:14 AM
St.Petersburg, FL
Feedback: +5 / =0 / -0
At the request of @toolmanmike I am posting in here. The original post in the Interior section was broader than just looking for a set of used ones. I had one bit of information from @YY1 beforehand sharing that it may be possible to use '67 ones, and if so I would be open to those too. Otherwise I presume that no aftermarket sources or alternatives (different models that share the same?) are available and I have to hunt for originals. That said, anyone got any?
Anyone happen to know if Plymouth GTX ones would work? I may have tracked down a set but it is quite a chunk of money to spend on a maybe.
Can't imagine that 67 tracks would be different or that ones from a GTX would be different either...
As stated in the other thread- 66 tracks are two piece and adjustable for height.
67 tracks are one piece and not adjustable.
IIRC 68/69 would also work and are very close if not identical to 67.
I should also note, I just need the 4 bases that bolt to the floor. Don't need sliders.
I have one side for a 67. I think its the driver side but not 100% sure. In case you come across another orphan.
