Drive Shaft Measurement
Charger Too
10:18 AM
Illinois
1968 Dodge Charger, 318, 8.75 rear end, 904 transmission. What is the proper method for measuring the length of the drive shaft? What length do I need? As long as the universal joints fits, do I need to be concerned about the length of the yoke? Thanks!
Fully slide the yoke into the transmission and then slide it out about 3/4 of an inch. You then measure from the center of the u-joint cap to the center of the u-joint cap on the rear axle yoke. This need to be done with the suspension loaded.
Fully slide the yoke into the transmission and then slide it out about 3/4 of an inch. You then measure from the center of the u-joint cab to the center of the u-joint cap on the rear axle yoke. This need to be done with the suspension loaded.
The engine and transmission are not in the car. I need to determine if the drive shaft I have is the correct one. I need to know how long it is supposed to be. I found some measurements in the parts book on how to measure the distance for the universal joint (3 1/8"), but the book does not explain how to measure the length of the drive shaft.
When I got a driveshaft for my a833 with 8 1/4 rear, I measured from the flat on the yoke to the end of the tailshaft. I sent the driveshaft shop the yoke and the measurements and the driveshaft fit first time.
Is the word "center" referring to where the universal joints are installed on both ends?
Some years back I started a thread about DS lengths....might do a search. Thing is, not all cars are the same due to production tolerances and 'minor' screw ups. A trim piece that fits one car but is 1/4" too long (width of the rear of the car) happens. I've experienced that first hand plus a wide wheel/tire wouldn't fit on side but did fit the other side of the same car and there were absolutely no signs of a crash on the cars. It's best to have the the drive line in the car and then take measurements. Too many charts are a 'rule of thumb' fit.
Center to Center is Center of the yoke saddles aka Center of the u joint cap to other end and Center of the other cap/yoke
Yes. The center of one u-joint bore in the driveshaft to the center of the other one. As noted above, factory tolerances were not great, so the best way is to assemble and measure, but that 56.17" came from the factory parts manual, so if your driveshaft is that length then it should work.
Then what anyone tells you is an educated guess.
Lots of times that's true but then there's that 'one of many' where that isn't true. Anyways, if the OP is wanting a DS that 'should fit' then go with a longer measurement then that way the tube can be at least shortened instead of starting completely over.
My thoughts exactly. If the op has a spare block and trans case, then it's easy to stick them in the car and get pretty close to what's needed.
The OP has a driveshaft already, and is just wanting to know if it is the correct one. I would never suggest having a driveshaft built to the length from a chart.
It's like wanting to buy pistons before you get the block :rolleyes:
