Cory M
Hey all,  I'm working on a 72 Satellite with the Qa1 front suspension (K-member and everything).  I have the Wilwood 12.8" front disc brake kit.  Anyway...I cannot get the caliper successfully centered and mounted.  It appears that the rotor is slightly off-center in the caliper - which of course results in not being able to get the brake pads in, or if I get them in the rotor won't turn.  Has anyone run into anything like this?  The only way I can see to remedy this, would be to grind a little off the bracket to bring things to center.
