mouse invasion
Rebelrouser
5:23 AM
Bland Missouri
OK I keep mouse poison out in my detached garage all year and have not had a problem before, but this year when I pulled off the car cover to get the car ready for a show, a mouse ran across my feet when I started the car and it smelled like urine inside. So I pulled the back seat and it had a mouse nest under the back seat. cleaned it out vacuumed and sprayed Ozium air fresher and throwed a couple car air fresherners under the seat before putting it back in. I got to the car show and while sitting in the street another mouse bailed out, friends thought it was hilarous. My car still has a wiff of mouse urine, if anybody else had this issue what is the best way to get the smell out?
That's some nasty stuff, and very hard to eliminate the smell completely imo.
Ozone generating air purifier. Plus figure out how they got into the garage and why. Any bird seed, pet food, water etc in the garage? If so, get it out.
Pests/vermin/millenials etc just need 3 things. Food, shelter and water. Eliminate at least 2 of those and your problem should remedy itself.
A vinegar solution to clean all surfaces. Carpet, depending on the extent, may have to be removed and thoroughly shampooed. As stated, check heater box & vents, vac and clean thoroughly. After cleaned, an open box of baking soda under the seat will help odor absorption. A natural scent is cedar oil which can be lightly sprayed afterward, or on a piece of cedar wood under a seat.
I have some that look like this
Some that look like this
Nothing expensive, but I've got them every 20' or so in both shops as well as the area where I work on motorcycles.
Mice hate the smell of peppermint! Put some cotton balls doused with it in different places in your car.
I hang two cotton balls from my garage heater and every week I give them a shot of fresh Peppermint
oil and I never see one. Your car will smell nice too! Some of the sonic generators work so look them up
on YouTube. You can get 16oz. of peppermint oil on Flea Bay for around $25.00. It'll last a year or two.
'BOUNCE' Dryer sheets, actually do help to repel them vermin also
helps some with the smell too...
Hydrogen peroxide,
also helped to clean where I thought the smell was coming from
won't hurt the carpet or upholstery either,
a lady told me to try it, seemed to help some
a good shop vac to suck it up too...
DECON bait then lil' like 1" green squares/mouse bait, works
(my pest control, Angles Pest Control guy gave me some, it helped)
we had them under the house too, put a lil' square on each pipe
& the A/C ducts where they run on/travel back & forth,
they were all gone (the squares) in 2 days, with in a week there
was no sign of the mice under the house or my garage...
I baited it twice, for good measures, last time I was under there
there were still some squares under there, been a while...
I didn't do the BOUNCE Dryer sheets for a while, at one time
& I didn't think there was any issues, got a bit lazy
with the vermin, you have to be ahead of them
(I do have 40 open acres right behind me, lots of critters)
a couple years ago we had a lil' issue with them vermin here
extreme winters/wet & deep *** snow, they wanted to get warm
my garage was the easiest place, my RR too :icon_fU: (mice)
normally hadn't had any problems prior,
I caught it early
saw a paper towel I had in the trunk, in a funnel got shredded
a nest made, lil pile in the trunk, it was left open too
I got proactive
no food or drink left outside on the decks or garage etc.
no feeders/bird feeders, no seeds (I like sunflower seeds), no garbage
no scraps left overnight (food in the garage left ever) etc.
seal all the holes where they can get in, expanding foam
or wood trim if need be, new garage door seals & weather seals for the side door
you'd be surprised how small a lil' hole, a rat/mice/vermin can climb through
I have a bud that was having serious problems on his ranch
them getting into his equipment, his feed & his trucks,
chewing wires & interiors etc.
He used mostly just old fashion mouse traps, he said he'd dump like 10 a day...
He tried the mouse electronic sonic repeller's, said "it didn't do ****"
he put like 4 of them big 12" x 12" 4 port Mouse Blocker boxes in his barn,
it didn't help at all, seemingly...
He did the BOUNCE dryer sheets in specific areas (inside the equipment),
he said it helped
but still didn't stop them all, it is a farm/a big barn after all...
I told him about the Decon 'them green squares',
my pest guys told me about
I tried & they work
supposed;
it doesn't kill the second animal that eats the vermin
that feeds on the DECON, "supposed to be safe"
around cats & dogs or other livestock secondary exposure
don't want them eating it though...
(lots of stuff for them vermin to eat or chew on or make nest of,
he tried them too, it also helped, but no cure,
it's a big barn)
DECON green cubes they/mice or other vermin eat it,
it dehydrates them & when they drink liguid or water, it kills them,
they bloat & sort of blow up
put/use the lil' black triangle boxes, that they sell for baiting them
that holds it & make sure weight them down so they don't get hauled off
we have 4 cats in close proximity now,
I'm friendly with them all, mostly any mice problem eliminated sort of too
I still do the BOUNCE dryer sheet, as a precaution
one in the trunk, one under each front seats, 1 under the back seat &
if the car sits for any time (like winter)
I put a couple in the engine bay too, like by the bulkhead connections
intertwined, under the dash, it always works here, if I remember to do it...
When we had an infestation in the really bad winters
I tried the electronic sonic deal, Mouse-Blocker (IIRC)
I saw on, one of the Saturday morning M/T TV Car TV shows advertised
it didn't last long, just died a couple months later...
I had one going out to my carport in back for the boat
& the mice ate the electric cord "to powering the mouse blocker",
that's not much of a repellant...
Tried another cheaper one, lil' plug in deals, 'ByCritter' was the brand IIRC,
that didn't last long either...
They did work, when they were working, but just not for long,
in my place anyway...
The few of my neighbors 3-4 cats, 'lil' killing machines'
seem to have killed off most the vermin in close proximity now
& unfortunately all the lil' critters, birds, squirrels, baby turkeys, baby quail,
gophers in my neighbor's lawn too
they every so often, will leave one as a gift/offering, on my back deck...
Good luck
Get a pail, straighten a coat hanger. Make a flapper similar to a valve in the carb. Could use a soup can lid.
Punch 2 holes near the top of the pail, opposite of each other.
Start the wire through the side of the pail.
Put the flapper on.
Slide the wire through the other side of the pail.
Smear peanut butter on the flapper.
Put a stick/board at angle next to the rod, from the floor to the top edge of the pail.
Put some antifreeze in the bottom of the pail. Mice fall when the flapper rotates. JOB DONE.
(DO NOT let pets access to the pail)
My father used to put wheat in an empty metal grease pail. Put a 1x4 against the pail. Mice would climb the plank fall in. Then cats would have a good feed.
I think I read somewhere that coffee will absorb smells.
I used ozone in one car to get a dead smell out.
BUT it did something to the elastic in the shoulder belts. The elasticity was destroyed.
I also plug the snorkels and tail pipes with steel wool.
Bought a truck, could not get it to run. Muffler was filled with wheat, cut it off and it ran.
Made a mesh dome on top of the fresh air vents for the car.
And spearmint. I just buy the small bottles of concentrated oil at Walmart near the candles. Around 20 drops in a windex spray bottle of water. Spiders don't like the smell either.
