jeepthrills01
I have an opportunity to pick up a set of TRW 2295s on the cheap...
Are these still relevent in a modern std stroke 440 build?
These are floating..not pressedThere's nothing wrong with them, but we've found that around 7000+ they start pulling the pressed pins out of the rod.. 6500 should be fine
The capability to float yes, but it appears they went the press route. By the lack of clips in the pictureThese are floating..not pressed
They are loose...can pop them right out.The capability to float yes, but it appears they went the press route. By the lack of clips in the pictureView attachment 1847521
Perfect. Did they hone the small end or put bushings in?They are loose...can pop them right out.
Neither...they are of the variety that use spriolocks...floatingPerfect. Did they hone the small end or put bushings in?
My bad. I thought these were the pistons you were talking about. With the rods installed.Neither...they are of the variety that use spriolocks...floating
They are..the pins push right out...either direction. There are no locks currently installedMy bad. I thought these were the pistons you were talking about. With the rods installed.View attachment 1847723
Ah ok thanks. Going back full circle, do the rods have pin bushings in them.They are..the pins push right out...either direction. There are no locks currently installed
Ahhh..now I understand! Sorry...roughly week. I'm headed to my storage unit later...will advise.Ah ok thanks. Going back full circle, do the rods have pin bushings in them.
