62 Plymouth sedan rear seat lower cushion fit ?
rustytoolss
11:10 PM
New Franklin, Ohio
Can any post a picture of how the lower cushion fitment where the lower cushion comes in contact with the bottom of the upper cushion (were your seat belts would come through) My car is a wagon, but think the lower cushion is the same for sedan. There is a gap area just above the driveshaft tunnel. I dont know if the was an early/late lower seat cushion...maybe.
64 wagon.
On my Dart 2 door, I had to fix the upholstery job done when I got it back.
The back cover was too high up leaving a gap and exposing the staples.
Also my lower seat frame was rotted and 'fixed' but I found and replaced with a good frame.
After that, I fixed it without any issues.
The frame could be bent, broken, or rusted.
The factory put a large piece of foam under the center section of the seat, but I never understood how that could have added any additional support.
Maybe junior used to stand there when riding in the back with no seat belt.
The seat frame is in good condition, did not know about extra foam under the center. Is your lower seat frame straight acrossed the back...mine has an area at that point shaped like the gap...was made that way. might be 62 thing only ?
My 62 back seat bottom frame.
This came out of my 4 door parts car, which I used to replace the rusted one in my 2 door, they were identical.
In pic frame is upside down.
