1970Bee
In another thread, I’ve asked for and received help on my car which turns out had a lifter failure. In this one I’m going to solicit some advice about changes I might make when it goes back together.
The car itself has great pieces- TCI 727, 3500 stall and Dana 60 with 3.91 gears, all of which are working as the should.
(This is where I’m making some assumptions based on my Brand X experience, so asking for input) The motor was put together in 2006 with high RPM operation in mind: Ross flat top pistons, ~248/254 577/584 SR cam, Team G SP intake and almost $1500 of work (receipts aren’t specific about what, exactly) on a set of 452 heads. A Holley Sniper EFI is on the car and seems to work very well. The car drove very well, but these specs tell me this motor wasn’t waking up much below 5k rpm and really wanted to rev to 6.5k, at least (my experience with Chevys tells me a 400 or so CI motor with that much cam, valve and intake volume would suggest that- I know the Mopar large bore/short stroke changes things, so I’m a bit lost).
I know the motor needs a new set of lifters and springs. Seems likely the cam, as well. No metal in the oil or filter, so believe the rotating system is ok. I’ve never “turned a car down,” but imagine doing so might make it more fun for spirited street driving, since it will likely never see the track.
So for those patient enough to have read this far (tried to be concise, but figured the background was pertinent), what are some recommendations for a fun driver? Smaller roller cam (maybe around 230 and 525 or so?), DP intake? Maybe a set of 440 Source or Eddy heads? What kind of power should I expect- 425 or so and at a livable RPM? I don’t mind the gear, but will my converter be too much if I have less cam? Or should I try to find a decent 440 and call it a day (cursory search doesn’t turn up many of those, but guess they are still out there)?
Not on a super tight budget, but do have other projects. And a wife . So not looking to just throw a credit card at it; but willing to spend a little where it will yield good results.
Sorry this was so long, but figured the background will help inform any advice given. Thanks in advance!
