Brutalowner
Im finally getting ready to update my Charger to make it perform like a modern LX chassis car, with the primary focus on the handling. The plan seems pretty simple and straightforward, but id like to hear input on the parts selection, mainly bar diameters.
Here is what Im working with-
1969 XP 318/904/ power drums, a/c p/s console car.
Completely stock. Owned since 1982.
What I have for the project.
Blueprint 408 that dyno'd 477hp
a built 727 with appropriate stall
aluminum 1350 driveshaft
8.75 rear with sure grip and 3.23/3.55/4.10- 3.23 being the primary use gear
Mopar XHD springs
15 x 8 Magnums
10.7 rear discs
Disco-tech style 11.7" front discs
tuned up and gusseted LCAs
Qa1 strut bars
Firm Feel UCAs
Borgeson box
1-3/8" anti sway bar
.940" R/T torsion bars
all other front components are new OE style.
275-60/15 Toyo 555S rear, 275-50/15 Toyo 555 in front.
Pretty basic, keeping the traditional 15" look.
Will it need bigger torsion bars than the .940"s? I imagine the weight savings from the Borgeson, the 408's aluminum top end, Sanyo compressor vs. the iron V-2 is considerable, but not having the typical B or RB weight in the nose
should be a help.
The shock selection is also up in the air. I have used the Vikings, and Ride Tech, but not Bilstein. Vikings are nice, but the price isnt. Whats the verdict there?
A rear sway bar- wait and see how it feels, or just count on needing it?
Round two for the car will be subframe connectors, most likely the US Car Tool scalloped style with all the adders, minus the rear frame over-axle plates. I dont plan on any type of cage, so the under car connectors will have to do.
I'd love to take it to a track day once in a while, but mostly it will be driven on twisty Country roads, with a few long straights...
Has anybody strayed from the traditional Big Block build and gone High Rev Small Block? This will be my first one, so any experienced thoughts are welcome.
Mopar XHD springs
15 x 8 Magnums
10.7 rear discs
Qa1 strut bars
Firm Feel UCAs
Borgeson box
should be a help.
