WTB P/N 2801890, A-833 Hemi 308 bearings
EWJ
3:26 PM
NJ
Feedback: +5 / =0 / -0
Seeking two aftermarket USA or German made 308 bearings or NOS 2801890 ones. Thanks.
Thanks for sharing, however do not want to use Chinese offerings.
I get that... Didn't know if they might have a source... FWIW if you find bearings from Japan (NSK) they are top notch as well....
Thanks for all this. However, thought the correct bearing is a 308 “SG” and that other 308 offerings wouldn’t work. That first SKF one in your links is an NG. Is it still a proper one?
Thanks for all the support.
Conferring with Dan Brewer, these two have incorrect dimensions for an 833. These offerings are 90 X 40 X 23 mm. The 833 308 needs to be 90 X 21 X 35 mm
I rebuilt a 833OD a while ago and was able to get 2 GM bearings 14095504 (GM used the 833 in pickups). They are stamped 308SG8. Worked perfect.
Thanks for sharing this.
