1969 Charger 500 grill pictures
SKR8PN
New Member
12:01 AM
Mansfield Ohio
Real long shot but gotta ask. Working on a 1969 Charger 500 with the flush mounted grill. I need to see some pictures of how the filler panel that fits between the headlight bezel and fender fits. This car was missing them but I just found an NOS set of the fillers and the mounting brackets. Just need to get some idea of just how they were located and fitted back in the day. TIA..
I have a C500 and can take off the headlight bezel and post some photos. But to make sure I address your questions, what specifically do you mean by "fitted"? Is there something specific that does not look right?....... because there is really only one way they can be installed.
Here's a picture from a 500 in the wild! Don't know if it helps.
Good luck!
The pieces I have, have a rubber strip around the outside edge where it contacts the fender. I need to see how far back from the edge of the fender those pieces fit.
This is an original untouched car. The rubber is pushed all the way back onto the filler piece and will be right up against the fender.
