JackBEEQuick
Hi all, I have been chasing a “misfire” for a month or so now, here’s the scenario:
I have a 69 coronet 440 engine for the street/strip
It Developed a misfire after a weekend of racing, made 14 passes total and started to get the miss on my 12th pass IIRC. That’s progressively gotten worse. Wasn’t do it until around 4800-5000rpm at first now it’s showing itself around 2000rpm.
Once got back home I realized I discretely broke a motor mount, thinking that issue was maybe tugging on a wire or messing with something in that regard I thought that could be the issue, replaced that, still there. I have new plugs, replaced cap, rotor, wires , it’s still there.
I then put in an all new MSD 6AL Box, coil, wires, the whole setup. The “miss is still there.
Thinking it’s fuel related now I then pulled the 6pack carb and intake and put on 750 Holley, that did not fix it either. I’m running out of thoughts on this… could it be an internal engine, torque converter (brand new Coan), or transmission issue? To me I feel like the “miss” or whatever you want to call it at this point , would be there at startup/idle if it were any of those things. Anybody ever encountered a similar gremlin?
To add I have the motor grounded from the head to the firewall and the front intake bolt to the negative battery post.
		 4 to 5 , I think is fine prob my cheap gauge lol .
