Ultra sonic cleaners
dan juhasz
12:57 AM
Whiting NJ
Looking to buy an ultra sonic cleaner. What have you bought and are you pleased with the purchase. There are a million Chinese units on Amazon and they all have some negative feedback. What recommendations are out there from what you have tried.
Bought a small one from Harbor Freight. Not heavy use but works as advertised. It is a couple years old now.
I bought one that I sized primarily for carburetor cleaning. It seems to work really well with the carb cleaning solution. I have found that it takes a while to heat up the solution so I usually ran parts through a couple of cycles. I’ve cleaned a couple carbs but I don’t have much to compare it to for durability and function. For carbs, the principal item I purchased it for, I’ve been satisfied with it.
I bought the largest one, 30L 7.9 gal.
Reading the reviews and talking to my friends, I got one with as little digital as possible.
I got it to clean carbs, and it works.
You have to be carefull as to what cleaning solutions you use.
Cleaning junk steel is easy with super clean. Or derust with vinegar.
I have mine set up next to a sink, so I can drain directly. You will be changing the water ALOT.
I wish I could have a bigger one, but the price point jumps to the thousands.
[/URL]
I bought one as well, been using it for 3 years only issue is the plastic covering the buttons is starting to crack, but they still work. Use it for carbs and engine small parts. found the Totally Awesome cleaner works very well for a reasonable price. cleans a carb in about 15 minutes. Buy LA's Totally Awesome All Purpose Cleaner, 128 fl oz from Dollar General - Instore
Same one I bought. I've used the Simple Green Extreme Aircraft and Precision Cleaner. Seems to work well. Agree it takes a while to get the water hit.
Vevor 30L unit here. Have used on a number of parts. I've had success with Spray Nine cleaner for steel items. Pine Sol with hot water for aluminum items.
Example shown: Valve covers that had two coats of paint and rust. Once the ultrasonic Spray Nine fluid was very hot, the valve covers were soaked multiple time cycles (shown mid-way through the process). Paint and oil removed. No harm to rubber.
Valve covers were then treated to Evapo-Rust soaks, sanded, primed and painted.
Note: Valve covers were too large for unit and had to be done half-at-a-time.
I purchased a Vevor unit about 3 years ago. Don't remember the size, but it is large enough to clean carburetors, which is the intended purpose. Quite happy with it. Cleaning solution varies depending on the task. Yes, it is Chinesium, but I have had no issues with it.
NOTE: When purchasing one, I would highly recommend getting a unit with mechanical timer and thermostat as opposed to the digital key pad version. Think about it. These vibrate (a lot) by design, so are shake, rattle and rolling that Chinesium circuit boards. The mechanical versions have been robust in my experience.
I had a 15l but it wouldn't fit an entire carb in it... so I sold it and bought a 30L.
Works good.
I just bought the bare bones least electronic 30L vevor cleaner. I read multiple negative comments on buying the fancier models with touch panels etc.
I also have the Vevor and have been happy with it after many years. I would suggest though, buy the biggest one you can (I believe mine is the 30L but ?? it was their biggest at the time) as you will find more and more you wish you could fit in it. I originally bought mine for doing carbs but they are very useful for many other pieces. I wish mine was much bigger.
Mine is the 30L and I have not seen anything larger advertised
Local to me and owner is a Top Alcohol Funny Car racer.
I see on their website, they currently have a 25 gallon version and retail price looks to be about $5300. That was the largest I saw listed, they also had several smaller.
