"Secret Photos" of the 68 Petty Road Runner at the Daytona 500
odcics2
12:05 AM
MoTown
Check out the details of the slicked up Plymouth!
Nice pics.
My takeaway:
1. Single circuit MC, all drums
2. It is very telling to me the front down cage bars appear ( but it might actually be there, unseen) to make no real effort to reach forward of the UCA pivot points, for reasons I suspect I agree with.
3. The Tb's appear to be rather healthy C body's
4. The rear is a 742?
5. The amount of streamlining underbody taken surprises me for that era
6. Rear springs do not appear to be as robust as I would expect, but the individual leaf thickness is an unknown in the pic
7. I suspect that jack point is near COG, and rather impressive that far back.
8. Don't see any telescoping/collapsing features in the engine compartment on the steering column
Thanks for sharing
The idler and pitman arms are quite the thing.
Nice pics.
My takeaway:
2. It is very telling to me the front down cage bars appear to make no real effort to reach forward of the UCA pivot points, for reasons I suspect I agree with.
Thanks for sharing
it looks? like theres 2 sets of springs on each side,along with a lowering block too.
stock set is light color,look on Top of those at the thinner black set?
those u bolt and shackles look like truck pieces too ?
I don't see double springs, I do see double shocks, which was the norm in the 60's in nascar, as shocks had not yet evolved.
The steering linkages are purpose built MoPar race pieces. The torsion bars have C body sized ends, but are shorter lengths.
Any idea what that linkage set-up gained for them? Improved wet sump oil pan?
That 8.75" rear was unexpected, hemi/4 speed, 600? Hp 3500 lbs,500 miles :eek:
Strength, over the flimsy stock linkage. All the MoPar stock cars used the 8 3/4, 1.75 straight pinion. Lots of gear choices from 2.76 to 6.13.
The 4 speeds used were standard 18 spline.
Drag cars are different animals!
The drivelines get shocked!
Remember, there were no pit lane speed limits in that era. Every pit stop was essentially a 1? mile drag race.
I also doubt any "soft" gear alloys would not last a high bank full throttle 500 miles so that was not likely an option.
I surmised it was a 742 rear, in that there is evidence of a wide range of ratios for it, that far surpassed the 489 availabilities.
The 489 was released in 68?
The 742 was used all the way into the 80s when the last MoPar stock cars were running.
Sometimes the gears would fail, but not often.
I was at every Nascar race at MIS from 1970 to 1978.
Hard to tell in this pic. It appears the adjustable strut rods are threaded on factory upper ball joints mounted into the K frame.
