Where are the flashers?
chrger1967
6:24 PM
I was feeling around under the dash of my 67 Charger looking for the turn signal and 4-way flashers. I could not find them. Where should I be feeling around?
Not sure on a '67. Left side of steering column and ash tray area? Or, turn one on and listen for it.
The flashers are in the glove box area down in the trough near the EL driver
Do you have 4 way flashers?
From the 1967 service manual:
Turn signal flasher:
Emergency flasher:
I do believe so yes. At least there is some
Is that what this switch is for? Was that an iption
Emergency flasher:
I found the turn signal flasher. I changed it and now I sorta have turn signals. It's probably the original one. It was a small square flasher. It was made in Brooklyn N.Y. Pretty cool, that's when stuff was made here.
I worked on upgrading the headlights to LED and found an odd problem with the flashers. I also changed the turn signal flasher yesterday to an electronic one. I found when I have the flasher switch lever down, not pointed at flasher, and I have either the right or left turn signal on. Both front marker lights will flash as if the 4 ways are on, but the tail lights will flash the correct side. There was a mention of taking out that switch and cleaning it, well guess what I'm going to have to do tomorrow. And I still have to find that flasher for the 4 ways, It has to be there somewhere.
Did you get reverse polarity grounded LED flashers.
The flasher I used only goes on one way, and the turn signals work great. I have yet to replace the 4-way flasher though, simply because I could not find it. I will have to search some more tomorrow. I'm sorta thinking it's the flasher switch, it seems to only happen when that switch is in the closed position.
I stand corrected, its only doing it in the off position. When I have it switched up to flasher, the turn signals operate correctly.
