Where are the flashers?
chrger1967
12:05 PM
I was feeling around under the dash of my 67 Charger looking for the turn signal and 4-way flashers. I could not find them. Where should I be feeling around?
Not sure on a '67. Left side of steering column and ash tray area? Or, turn one on and listen for it.
Do you have 4 way flashers?
I do believe so yes. At least there is some
Is that what this switch is for? Was that an iption
From the 1967 service manual:
Turn signal flasher:
Emergency flasher:
I found the turn signal flasher. I changed it and now I sorta have turn signals. It's probably the original one. It was a small square flasher. It was made in Brooklyn N.Y. Pretty cool, that's when stuff was made here.
I worked on upgrading the headlights to LED and found an odd problem with the flashers. I also changed the turn signal flasher yesterday to an electronic one. I found when I have the flasher switch lever down, not pointed at flasher, and I have either the right or left turn signal on. Both front marker lights will flash as if the 4 ways are on, but the tail lights will flash the correct side. There was a mention of taking out that switch and cleaning it, well guess what I'm going to have to do tomorrow. And I still have to find that flasher for the 4 ways, It has to be there somewhere.
Did you get reverse polarity grounded LED flashers.
The flasher I used only goes on one way, and the turn signals work great. I have yet to replace the 4-way flasher though, simply because I could not find it. I will have to search some more tomorrow. I'm sorta thinking it's the flasher switch, it seems to only happen when that switch is in the closed position.
I stand corrected, its only doing it in the off position. When I have it switched up to flasher, the turn signals operate correctly.
