Coelacanth
- 11:38 AM
- May 10, 2024
- Edmonton, Alberta, Canada
I had the seat frames out of my car for restoration and upon reassembly, I noticed only the driver side frame had this thick beefy spring, in addition to the small yellow outer spring for the adjuster lever, and the cable that joins the adjuster levers on both halves. However, the passenger side frame is lacking this big spring. It otherwise works fine after reassembly, the adjuster lever and cable releases the adjusters and the seat will slide forward/back. It just seemed odd because it appears the passenger side frame has mounting spots for this big inside spring. Do the passenger side buckets not have this spring?
