How to identify B-Body (or E-Body) firewall mounting plates | 1962-1974 | manual vs. power
cudak888
4:53 AM
South Florida
***Repost of 2016 thread w/photos restored***
Last night, I wound up doing a few forum searches, trying to figure out if I needed to change my firewall bracket for my disc brake (non-power) conversion (I was also inspired to do so after reading this thread).
After sorting through all the info I found, I realized that the firewall plate variants are really quite easy to understand - provided all the information is in one place, separated by year. But it isn't...so #newthread.
I compiled everything I could find and assembled the following chart below. For the sake of identification, I copied a few photos that I found here that demonstrate the differences, and credited the sources (hope you fellows don't mind), as I'm not lucky enough to own every single plate made.
Would also be glad to edit and update this as more information comes out. One of the things that I can't find yet is a photo of the bellcrank on a power brake-equipped '65 (which I'd assume are rather unusual to begin with).
1962-1965 B-Body:
Manual booster at left, power booster at right. Power booster requires bellcrank. Not reproduced. | Photo: moparmarks:
1966-1970 B-Body:
NOTE: 426 HEMI applications use manual master cylinder firewall plates and a much larger bellcrank that's built into the booster standoff (photos of this complete assembly shown in last section below).
Booster bracket for cars with manual master cylinders OR power brake HEMI 426 applications. Original shown. Not reproduced. | Photo: challengersteve
Power booster bracket for all applications excluding 426 HEMI.
Requires standard power booster bell crank without booster standoff.
Original, shown from reverse side Photo: 69bee:
  • Reproductions of '66-70 power booster brackets (the same thing above):
  • Version #1, shown with bellcrank:
  • Version #2, shown with bellcrank. Only apparent difference are the two extra holes. NOTE that I suspect this might be a vendor's Photoshop of a manual booster plate with the holes moved around, and that the only one you can actually get is the first version. Either way, it'll make no difference in operation:
1971-1974 B-Body + 1970-1974 E-body:
Original | Photo: moparmarks:
Reproduction by Dr. Diff | Photo - Dr. Diff :
Power booster bracket for all applications excluding HEMI 426. Requires bell crank for proper operation.
Original | Photo: eBay, wolf-pack68
Reproduction (shown from the rear, rotated 90 degrees) | NOTE: Some sites show a stock image of this part, but show it six holes that don't appear to line up with the original. These places have Photoshopped the '66-70 power bracket to look like this.
Pedal rods, bellcranks, and other things you should see to know - 1962-74(ish):
Manual brake rod:
Manual brake booster rod shown on a 1968 B-Body:
Power booster w/bellcrank for 1966+ applications, bellcrank pivots from bottom. Note: I believe 1965 is inverted and pivots from the top, but have not found a photo of one | Photo: moparmarks:
HEMI 426 (factory Gen II) booster (Note manual brake plate mount and built-in bellcrank. Offset plate and oversized bellcrank currently reproduced). | Photo: Chattacuda:
That's it - six plates with eight unique factory applications, spread over three generations of B-bodies. Not really that complicated.
-Kurt
Someone DM'ed me about where you can get the Hemi offset bracket.
There's a cad-plated Gen II Hemi bracket only that makes the rounds as a "1965-1970 Mopar Brake Booster Bracket." They're usually sold as a "power brake conversion bracket" for A/B/E Bodies. Part of that marketing makes me think they're taking advantage of people that don't read this thread and aren't aware of the proper bellcrank for B/E bodies without Hemis, but that's another story.
Either way, they're on eBay and other places. Play around with the search keywords "Mopar Brake Booster Linkage" and you'll probably find them eventually. Here's a link to an overpriced one ($98 - the same bracket is listed new on eBay for $58), on Speedway Motors - though the link will probably be dead in a year or two if they modify their website; seems to be the case with most links I find in older threads:
https://www.speedwaymotors.com/1965...5o6OGhCfTHIcTypV7eVkjKhfCjbumnQBoCs8MQAvD_BwE
Dr. Diff sells a different reproduction with the booster. This one is painted black and isn't from the same tooling. You'll find it a $225 option in the menu.
https://www.doctordiff.com/bendix-style-dual-diaphragm-booster.html
This said, I wouldn't fault anyone for installing one of these offset brackets on a daily driver with an LA or RB, and I'd recommend it if your build prioritizes maintenance over originality. The Hemi bracket makes servicing massively easier if you have to pull the booster, as the nuts are relatively accessible. Ditto for the master cylinder - no more unbolting it from under the dash and around the pedal box.
<rant mode on>
There's a very good reason I recommend the Hemi bracket for servicing: Removing a firewall-mounted booster from a fully-assembled '66-70 B-Body is a job invented in the fieriest depths of hell, and I sincerely hope the engineer who came up with the design is there now - and is being used as a voodoo doll.
It's one of those things where I'm still utterly mystified why Chrysler engineers were so intelligent with the A-bodies (knurled studs from the firewall out) and so stupid with the B-bodies (knurled studs on the master leading to one nearly inaccessible hole, and one totally inaccessible hole). This repeats itself all over the dashboard areas of these cars - A-body is an intelligent joy, B-body is a maddening mess. Doesn't make sense.
</rant>
-Kurt
Kurt so im still a little unclear untill i lookat more brackets. But your help is priceless. My next project is ac box. I want to find a motor that is real short so i can put the traditional air ac box in the car with a short blower motor so hemi valve cover wont hit the blower motr any idea where to find?? I have the bracket btw for hemi booster but im hoping the off set one your talkin about is considerably more off set
There should be only one HEMI-style bracket - they probably all follow the same specs, and thus are offset vertically the same amount. If they didn't, there would be linkage ratio differences.
Perhaps there are alternates, but I haven't tinkered with any of them to find out. I've only played with the standard bellcrank and booster repops.
Funny enough, and after having my repop booster leak and endless master cylinder issues (upper cover leaks + surface rust + fluid leaks), I lost patience and went straight back to manual disc/drums, installed the two-bolt master adapter plate, and fitted a modern aluminum master. Archaic, but it simplified the system, and it still feels good. It also made it a cinch to pressure bleed the system (which, in my case, was a necessity due to trapped air that was proving an impossibility to purge via conventional pedal bleeding).
-Kurt
Great thread cudak888....
I am confused (ski at the end of my name)
I removed this unit from my 70 Superbee (it was drum and I added Power disc a few years ago)
Now I am installing this unit from Classic Industries:
My question is: How does this mount to the firewall?
Is there a bracket guys?
This in itself ...does it just mount to the firewall or is there a bracket it mounts to as in the GM style?
Bendix Style Dual Diaphragm Booster for Mopars
<rant mode on>
</rant>
-Kurt
i know this is old post.. but has anyone done this setup with the M/W manifolds? or maybe this one? looks a bit smaller.
A quick image search pulled up three Max Wedge cars with power boosters. While none of them are stock, the one thing shared amongst all of them are aftermarket, lower-rise headers.
Now consider this tasteful restoration with the high-rise Max Wedge headers. It's not numbers matching, but there's an attempt at an original look here. The factory manifold and the dual master upgrade just barely clear each other.
Now consider that while you're raising the booster with the offset bracket, you are also dealing with a larger diameter object in the same place as that master cylinder reservoir.
I'd say the concept of running the MW exhaust manifold with the Hemi offset bracket falls under the category of science fiction, unless you can identify the unicorn that is a small diameter single diaphragm master with the correct bolt pattern for the offset bracket. Even if it exists, my guess is that the smaller single diaphragm will not perform adequately.
-Kurt
-Kurt
Looking at the pics y'all put up. Even if I did use it with or without single bladder. The manifold will boil the stop juice and probably melt the seals. O well 5/8s inch master should be good enough..
I saw one or two examples similar to the latter - factory manifolds with a flat heat shield under a manual dual circuit master cylinder. I bet it's a problem even at that distance.
-Kurt
I put power disc's out of 72 Charger on my '65 Coronet, Indy MW heads on a 440, Original MW manifolds matching yours , used offset MP 1" aluminum master, I had No problems although I did put an insulated shield underneath - can't get at the car for pics or bracket ID right now, sorry ! Original post - I made my own gaskets[steel reinforced sheet] for the exit flange when I needed to pull it apart 1 time , as well as the pipe flange[1/4" plate IIRC] that muffler shop built exhaust to - Never alot of room but you make it work somehow if you want it ‍♂️
You're the first to have reported success - let us know when you can get to the car and snap a picture. That's definitely worth documenting.
-Kurt
