Silicone Brake Fluid
But my real point was, that long known observation seems to be mostly ignored and avoided by silicone advocates.
"Why is the topic of why EXACTLY silicone BF's are not allowed with ABS would I suspect be rather telling.
I am not catching what you're getting at? It's not used because the frequency of the solenoids in an ABS hydraulic unit coupled with the pump agitation, causes the fluid to foam. DOT 5.1 is also synthetic and does work with abs. Neither one works in a power steering box either, but that doesn't mean a thing. It's not a debate topic, no right or wrong, it's preference, plain and simple. I went with it because my cars sit a lot and I don't want moisture from our humid climate to cause any issues with my brake system investment.
"I am not catching what you're getting at?"
I am getting at why are the downsides to silicone seldom if ever mentioned? It aerates, and it is compressible, relatively. Nearly every solution has a downside. You are the first here, #21, to post one of them. Is that acceptable by some/many, sure, but it's best if they know it first, and that means it must be part of the discussion, and that is rare, IMO.
Debate would mean I disagree, not ask a question. I will however question the premise that humidity is the source of BF moisture absorption that causes brake fade/corrosion. I'd like to see the research that explains how prevalent air borne humidity is that enters a somewhat sealed MC and travels many feet thru a fairly small steel tube to the heat source (caliper) that boils said moisture. when the fluid only moves an inch or so back and forth in normal use. We are for clarity ignoring the bleeding of any possible moisture laden BF from the MC down to the brake cylinders/calipers. I lean towards most moisture issues with BF are from very old BF, or cars driven in the rain and parked wet, or deep puddles, entering the system from the caliper end, especially regarding corrosion, which we have all seen.
I would disagree based on my 50 years of working on vehicles. Brake fluid by its chemical nature is hygroscopic. It absorbs moisture. You are saying that water would 'boil off', which is absurd an assumpton because the moisture has reacted with the fluid and cannot 'boil out', if it did, it would create a gas bubble in the brake system and you'd lose hydraulic pressure in the system as a gas can be compressed. The moisture is homogeneous throughout the hydraulic system, turning the fluid corosive. Moisture gets into the system, plain and simple. Let's address that fact that doesn't get discussed about DOT 3 and 4 fluid, it degrades over time as humidity(water) makes it's way into the system. The master cylinder covers on our old cars were notorious for leaking fluid, that means that moisture in the air can also make its way into the fluid. This causes it to rust from the inside out. According to your view of the system, brake fluid would never need changed, parts would never wear out and brake lines would never rust through. It is possible for moisture to wick into the system, yet fluid to not come out due to the very nature of the lip seals used in wheel cylinders, master cylinders and calipers.
Not sure I’m following you, but none of my 4 old cars have anti-lock brakes so it’s kind of a non-issue for me. Works great in my 2 MY66 cars.
I don't dispute your claim, but silicone remains compressible and aerates no matter what the system it is used in.
I would disagree based on my 50 years of working on vehicles. Brake fluid by its chemical nature is hygroscopic. It absorbs moisture. You are stating the obvious, but you have not addressed how the amount of hygroscopic effect is had by a single pin hole vent on the top of the MC and that absorption travels many feet thru a small steel tube all the way to the caliper which is the ONLY heat impacted component of the brake system, understanding the fluid is effectively static except under application when it might move bidirectionally an inch? You are saying that water would 'boil off', which is absurd an assumpton I never said "boil off" because the moisture has reacted Not sure if it really "reacts" I submit it does not with the fluid and cannot 'boil out', if it did, it would create a gas bubble water boils at much lower temp and why it is anathema to a brake system in the brake system and you'd lose hydraulic pressure in the system as a gas can be compressed. That "boiling" you note" is however the often cause of heat brake fade, no matter what the condition of the brake fluid is The moisture is homogeneous throughout the hydraulic system Can you support that claim?, turning the fluid corosive at what point of "turning" can you support that claim?. Moisture gets into the system, plain and simple. How? Let's address that fact that doesn't get discussed about DOT 3 and 4 fluid, it degrades over time as humidity(water) makes it's way into the system. I submit the small amount moisture that might travel very slow if at all thru the lines and causes little if any harm until somehow it reaches the calipers or wheel cylinders The master cylinder covers on our old cars were notorious for leaking fluid, that means that moisture in the air can also make its way into the fluid. This causes it to rust from the inside out That effect is caused best by consolidated water sitting in a brake line at one spot for a length of time, and hence why the hygroscopic effect is useful because water cannot coalesce for long in one spot inside a brake line, it is absorbed and diluted. According to your view of the system, brake fluid would never need changed I never said that, parts would never wear out and brake lines would never rust through. It is possible for moisture to wick into the system, yet fluid to not come out due to the very nature of the lip seals used in wheel cylinders, master cylinders and calipers. I agree, but I can't prove that, you are welcome to. I addressed by my mention previously water might enter the caliper/wheel cylinder by water immersion and/or wet driving, and parking the car wet before the moisture could be heated out of the seal area by driving/braking.
Omg, I am not stating an opinion. I won't waste my time with my credentials. It permeates throughout the system. It doesn't boil off for the same reason it doesn't boil off from anti freeze. Do you even know what brake fluid is made of? I do. Polyglycols. Meaning, multiple types of xxglycol mixed together, one being ethelene glycol, ring a bell? Yep, anti freeze. I'm not going to let you drag me down to your level and beat me with experience in an argument. Enjoy your blissful ignorance and have a wonderful day! I will be ignoring further comments, I win!
Other than a personal attack, you have shared nothing more than your anger and inability to address my specific counterpoints.
Maybe if you take a short time out, you might be able to rejoin the conversation less hostile later.
Ignoring is related to "blissful ignorance" I am told.
I'm all in on DOT 5. My '72 no rust Dart wouldn't have a hole in the floor, on the driver's side, from moisture absorbing brake fluid from a leaking master cyl if it had DOT 5 in there. Never use that crap again in my 3 old cars.
I converted my Austin-Healey to silicone fluid in the 1980s, first flushing the lines with isopropyl alcohol. Never had any leaking or any other problems since, but there is one downside to silicone. If you get it on painted surfaces and need to repaint them at sometime down the road, it's very difficult to get the fisheyes out of the paint. I converted my Charger to silicone after the restoration.
So, one fluid if spilled requires a repaint and the alternative fluid if spilled prevents a repaint?
Interesting :lol:
So who out there is spilling all this BF anyway?
Interesting :lol:
Exactly! I also have an MG Midget with silicone fluid and it required a repaint due to an engine bay fire. Seemed like no amount of sanding and cleaning would get rid of all the fisheyes (fortunately, in the engine bay only). Still, my belief is that silicone is less of a problem than DOT 3 or 4.
