Radiator
Aron Gleason
4:49 AM
Washington
So I recently had a couple fan bolts come loose and dug themselves into the radiator. Glen Ray radiator said he could fix the damage and id only lose about 6 tubes out of 265. Whats everyone's thought on that? And he said he won't charge me to fix it since I bought it from him back in 2019.
You have nothing to lose and everything to gain if he can fix it for $0. That's a pretty nice offer after 6 years of use. And somehow I doubt that Glen Ray would offer to fix it, especially on their dime if they weren't confident that the radiator would function properly afterwards.
Good point. 1 shop local to me said if its a simple fix they would charge me around $140, or a worst case scenario they would have to recore it for $1000.
It does. But trying to find a box is the hard part. Every place I've called said they don't have anything that size or they break them down. And im cheap, I don't want to buy a box cause that would defeat the free cost lol.
Look in recycle bins behind shopping center for cardboard boxes. And you can fabricate a box with either an oversize box, or combining smaller boxes. Done so plenty of times shipping parts.
That's a good idea.
Your local Walmart gives out free boxes, let them know that you’re looking for one.
I had a floor jack slip off my K frame. Found out quickly the alum radiator is rather lacking as a jack point. My ego was the most damaged.
I thought the rad was worthless, but it got repurposed as a rad for engine stand and works well and is a constant reminder to never let that happen again. If nothing else and you build an engine test stand, that problem is solved.
Its definitely worth fixing IMO.
Do I see raw copper exposed on the fins? I was assuming for no real reason other than slight pic overexposure it was an Alum Rad.
Its a copper radiator, no aluminum radiator for me.
Copper is indeed a wonderful material, accepting of course, its heavy and costly
With today's copper scrap values, your damaged radiator scrapped might just pay for a new aluminum radiator if you wanted or needed to go that route. :eek:
Well I was going to send it to Glen Ray radiator cause he wouldn't charge me anything to fix it. But now im thinking of trying a local radiator shop that's highly recommended. And hopefully I won't have to take out a loan to pay for the repairs.
I would think copper would be fairly easy to solder plug the damaged tubes once the tanks are removed. The damage in your pic would be hardly noticeable with a fresh coat of black paint. Is it heavy to ship?
A copper rad is always going to be weaker than an alum rad because the tanks are soft-soldered to the core....& soft solder is not very strong.
I don't know about that. I was told a aluminum radiator doesn't hold up as good as a copper radiator.
Absolute BS.
An alum rad is brazed construction. Also, the alum radiators have wider tubes, 1" or wider, that copper cannot. This results in a larger fin area. It is the fins that dissipate the heat. Also, the way the fins are louvered is better in the alum rad, making heat transfer to the air greater.
Only thing you need to do with the alum rad is make sure you use the correct corrosion inhibitor for alum/iron engines. I have had an alum rad in my car for nearly 25 yrs; no corrosion.
I don't even know which company makes the best aluminum radiator if I went that way? And it would have to have factory mounts for my shroud.
