Headlight splash shields 66 charger
Stowe
10:55 PM
NY
Hello ,
Does anyone have a picture of the headlight splash shield installed . My car came back from paint and body with a box of shields . The rubber was replaced in the shields but they were not installed .
Unfortunately our car is still in the body and paint process and will be for awhile, so I unfortunately do not have any pictures for you… and ours were so bad we threw them out as well, so I am wondering where to get new ones. Also, @Don Frelier, @Greg Ducato, @440 4 speed, or @RedBeard could possibly help you out. I will be following this.
Watching I would like some myself mine has none
Thanks, I just not sure where it bolts on .
Hold the splash shield up against the front fender frame behind the headlight area. The gasket side will follow the contour of the inner side of the fender. Then the holes in the shield will line up where the spring nuts should be.
Here is a picture of one I'm pretty sure has never been apart. Passenger side, drivers side is too crowded with stuff to get to.
If a better picture is needed? I can provide.
Thanks made more sense once I was able to get the car in the air see how it laid out f for some reason I was thinking they went between the rad and core support . Thanks again
