lumbee
- 11:02 AM
- Jan 24, 2024
- Asheville, North Carolina
Hey all, getting close to running my 400 after a fresh rebuild and I have a question. Also, I fully acknowledge I should have thought more about this before this point, but here it goes.
I have 1972 Roadrunner (4 speed manual) and the numbers matching 400 block came with the car; the block only. I was able to purchase a good used 1976 400 engine and I have swapped all of the parts off of the donor engine into the numbers matching block, including the crank which also had the external harmonic balancer. I was told the donor engine came out of a Chrysler New Yorker so I'm guessing it was most likely an automatic transmission; though I'm not sure that matters. I have [what I believe to be] the original flywheel from the '72 RR along with the bell housing and manual transmission that I am planning to reinstall in the car.
Here is my question, can I use this flywheel? I'm concerned about it being balanced or neutral; I'm thinking its neutral but what are the implications either way? I really do not want to tear this engine back apart to balance it, but you all tell me what you think please.
