gasket material
leutdan
12:32 PM
Keller, TX
Can someone direct me to a source for the material installed between the fenders and frame along the surfaces where the fender bolts and u bolts attach the two.
It looked like a black spongy tar/felt material when I took it apart after 50 years of protection. If there is no source for the original material are there any good suggestions
for a substitute. Would prefer to not use something like a Home Depot building material. Thanks gentlemen
I have some 1/8 inch butyl rubber material that I could cut and make a gasket but that might be too thick and cause misalignment.
Could it originally been seam sealer from the factory?
Thanks for the responses. mopar4don, it could have been something like that, however it was too uniform/straight across the top and had a consistency that seemed to have a strand of fiber like a fabric or rolled material. pnora, I have that product. Do you just string multiple strands of that because mine is pretty narrow, like rope. Thanks again guys
Thats all I do. Once things are bolted together is squeezes out and fills the voids.
I use 3M strip caulk.
Sometimes referred to as 'Dum-Dum' - looks a lot like Blue-Tac.....found in the Craft section of Stationary stores.
