Do I really have to remove the pan?
chrger1967
10:24 PM
Looks like I have a nice puddle under my Charger that I haven't had the pleasure of driving yet. It looks like it the dipstick tube seal. Do I really have to drop the pan, or can I just catch whatever fluid drops? The car is up on jackstands, so working on it isn't so bad, I just don't want to make a mess with the fluid. Funny thing is, I wish I had known if was going to leak, the car had only a little bit of fluid in it when I brought it home.
I'm thinking the automatic transmission tube?
Have a pan under it and pull the tube.
Having the rear of the car lower than the front will help to not loose as much fluid.
funny you should say that, as I was writing my post, I was thinking if that would help. I was thinking of just lowering the jackstands as far as I can.
Take a piece of aquarium tube... mark it an inch longer than the dip stick tube. Stick it in until the mark, suck and let the siphon do it's thing. New o-ring with some sealant, let it cure a couple days and then put the removed fluid back..
Or you could drop the pan, replace the filter, fix the leak, and replace the pan with one with a drain plug. This will be one of those nagging problems that will bug the F out you until you fix it correctly. Nothing worse than seeing fluid leaks under your car. It’s a simple fix, just bite the bullet and do it.
Not to be funny, but are you checking the fluid level properly ?
Proper procedure is to park on level ground. Start car and warm up to operating temperature, place transmission in Neutral only ! Check fluid level, should be about 1 pint low to be proper amount.
Must check in Neutral.
You didn't say if you trailered or home or drove it. 8 qts down, it would not move at all.
Oh yeah, I'm checking it in neutral after I let the engine run for a bit. Being that the car is on jackstands, I've been putting it run in gear for a few minutes.
