FOUND Need blower motor cage for 70 ebody heater only car
Sedbld
3:51 PM
Virginia
Feedback: 4 / 0 / 0
Anyone have a plastic blower motor squirrel cage for a heater only car for sale? It’s stamped with part number 2837679. It’s from a 70 e body and measures approximately 4 3/8 across and 2 3/8 tall. I have one very close to the same size out of an abody but not as many fins and is metal. Thanks in advance. Mark
I could use a metal one if anyone has one that’s same size
I went trough my parts books, the part# is 22277597 is use in E Bodies from 70 to 73 and A Bodies from 65 to 73. Vendor suppliers may have different versions through the years but same part#. There are times that part#'s and casting #'s don't match. This wide a window should help you locate one.
Hope this helps
Jeff
Thanks Jeff for the legwork. Really appreciate it. I got one out of an abody heater only box but guy didn’t remember what year it was from. It was stored in a fully packed shed and had been there for years. It’s a metal one that’s extremely close to the diameter and same height but it’s got less blades. Definitely from a different supplier. Don’t know if that would make less cfm than the original one? That’s the only reason I am seeing if anyone has the plastic one. If I can’t find a good used one I’ll probably just use it.
