Charger-Man-NC
I drove it last fall. I put it in the warehouse where I store it. I went to get it in April. I had a very hard time getting it started and it would just stop running. When I would put it in gear it would kill the engine. I found a bad wire harness. Replaced it, distributor, coil, ecu, battery, plugs, plug wires. It turns over but doesn't seem have to any spark. I put a timing light on the coil wire but no spark. I even put a new points distributor in and the same problem. I have put a jumper wire from the battery to the coil positive side when trying to start it. Also, it won't turn over with the key. I put the ignition switch in the run position, with the jumper to the battery and use a remote start switch. I have noticed that the battery cable going to the starter seems to smoke a little when turning the engine. Any one have any ideas?
