66 Charger won't start
6:44 PM
Kernersville, NC
I drove it last fall. I put it in the warehouse where I store it. I went to get it in April. I had a very hard time getting it started and it would just stop running. When I would put it in gear it would kill the engine. I found a bad wire harness. Replaced it, distributor, coil, ecu, battery, plugs, plug wires. It turns over but doesn't seem have to any spark. I put a timing light on the coil wire but no spark. I even put a new points distributor in and the same problem. I have put a jumper wire from the battery to the coil positive side when trying to start it. Also, it won't turn over with the key. I put the ignition switch in the run position, with the jumper to the battery and use a remote start switch. I have noticed that the battery cable going to the starter seems to smoke a little when turning the engine. Any one have any ideas?
It seems you're trying to circumvent the starting circuit and ignition circuit without trouble shooting either circuit for proper function. You have an ecu harness, but you now have a points distributor. Seems like you got things all mixed up. Troubleshoot the basic circuitry to find your problem.
Moisture inside the distributor cap ?
That means you have a loose connection in that cable - causing higher than normal current draw - hence the heat & smoke build-up.
Similar situation for me a few years ago - I had a problem with starting a FORD Falcon a few years ago..... hot or cold it was sluggish to strta- as in turn over on the starter.
After investigation and some testing, I found the starter was bad - all the carbon on the brushes had built up over the years and caused massive internal shorting across the commutator. As cheap as they are I replaced the starter with a new one and the car has never sounded better.
BTW - trying a new battery before diagnosing the starter issues only served to kill a new battery. And cranking the engine on that new battery with a bad starter heated up the battery real fast and also started to soften all the starter wiring......so be careful. :)
Thanks for your input.
Hooked up the points distributor as it should be. I disconnected the ECU wiring.
Seems you may have two problems:
- failing to crank
- loss of spark.
I found out why it wouldn't crank from the key. The Neutral lock out wire had come unhooked and when I put it back on I didn't connect it correctly. I put it on correctly and now it will crank using the key. That didn't help the no spark problem. Thanks for the input.
