Disc brake swap
Milo
1:07 AM
Pa
If i put disc brakes on the front end of my 67 and want to keep the 14 inch wheels can I use a Volare front? If so what will I need to do it
Dr Diff has it all and almost plug and play.
You need to use the smaller 10.89?? Rotors for 14 inch. And the corresponding caliper bracket for that size rotor.
Ssbc are an easy swap and don't require changing the spindle.
Scarebird conversions are mentioned on a few threads here you might want to consider, also.
I usually use western chassis for the spindles and source the rest of the brake parts via rock auto. But it looks like they have a kit available now
I personally used 1973-76 A body setup. Power or manual, your choice. Used DISC BRAKE 14" wheels. Yes, the drum brake wheels ARE DIFFERENT in the backside area and will rub the caliper. There are Magnum 500 disc brakes wheels out there and ALL new 14" wheels clear disc brakes.
I removed the front spindles, rotors, calipers, pads and proportioning valve from an 80 Aspen. I put them on my 60 Dart along with a new master cylinder for the Aspen. They have been on there for 20 years and clear the stock 14" wheels with no issues except my Bellows booster does not provide enough boost to lock the brakes. Front or back. They still stop the car better than the dual cylinder front drum junk that was on the car from the factory. If you have Power drum brakes now, You would need to upgrade your booster to a dual diaphragm booster. This one. https://www.ebay.com/itm/236250969723?
