Fender Tag Replacement
DMateya
9:17 AM
Pittsburgh, PA
Hello,
When I purchased my car it did not have a fender tag. For restoration purposes I am hoping to get a replacement made. I understand it is not the original one and is more of a novelty but does anybody know where one can be made?
Thanks,
Drew
Backlash in 3...2....1....
Without some sort of underlying documentation, it will be difficult or impossible to replicate an original tag.
There are plenty of companies willing to take your money and stamp codes in a piece of metal resulting in something that resembles a fender tag.
Some of those vendors will be mentioned here.
If you care nothing about accuracy and are willing to suffer the consequences of having a bad tag on your car, then any low budget vendor will do.
My Roadrunner came with no fender tag and I'm fine with that. I made the car what I wanted and am not trying to fool anyone into thinking it is original. Heck, after more than 50 years, how many are out there like mine, that have been rebuilt the way the owner wanted.
If it has no tag, let it be.
You must realize the rabbit hole you are wanting to fall into.
And, with that, good luck and enjoy the car for what it is. JMTC
I am a person trying to get another roadrunner back on the road so helpful comments are appreciated. If the correct answer is no do not re-create a tag and keep that space open then say so. I enjoy learning about my car and going through the restoration process. A re-created fender tag can have clear markings like and X that shows its not real. Passing off a piece of metal as a real fender tag is not what I am looking to do.
I am a person trying to get another roadrunner back on the road so helpful comments are appreciated. If the correct answer is do not re-create a tag and keep that space open then say so. I enjoy learning about my car and going through the restoration process. A re-created fender tag can have clear markings like and X that shows its not real. Passing off a piece of metal as a real fender tag is not what I am looking to do.
You are better off without a Fender Tag in this situation.
It is meaningless in the fact that it will never be 100% authentic, and for that reason alone, most guys here would advise you just leave well enough alone. :)
Thank you, that sounds good to me.
MMC Detroit marks the tag to show it's a reproduction if you don't have the documentation for your original tag. Who cares what others think. Put a tag on it if you want.
GTX, I expect a copy of the original Build Sheet would be documentation enough?
That's a common misconception.
Having the BS is certainly a good place to start, but simply having the BS does not ensure an accurate tag.
Tag codes change year to year, plant to plant and even within the model year.
The BS does not tell you which codes go on the tag, what time of the model year the codes are supposed to appear on the tag, when codes are paired (IF/THEN coding) or even where on the tag the code is supposed to go. You still have to have someone with the right knowledge to accurately layout a tag.
The BS does not tell you unique tag data like Lynch Road Gate and Base codes.
The BS does not tell you which codes supersede other codes on a tag (the Jefferson plant superseded a lot of codes)
The BS does not tell you plant nuances like when the '69 Hamtramck plant transitioned from stamping END on the tag to EN1 and EN2.
The BS does not tell you when certain codes appear for certain models at certain plants. Different plants coded differently.
Making accurate tags from scratch requires a BOATLOAD of homework that the vast majority of tag makers NEVER do. To make accurate tags, one has to learn every tag detail from every plant from every time of the model year from every model and every body style.
Plenty of crap tags have been made even with a BS available because the tag makers don't know what info to use from the BS or when to use it.
But, there are plenty of people that will take your money, stamp some codes in a piece of metal and sell you something that resembles a factory fender tag. Some of those vendors will probably be listed in this thread by well meaning folks.
I'm thinking a knowledgeable vendor could make a pretty accurate tag with a build sheet.
One would think but it is far, far harder, if not impossible, to recreate an accurate tag from scratch, even with a BS, than most people realize.
It's just not that simple to make an accurate tag.
My GTX had no fender tag when I got it, and it is very liberating!!! Freedom to build the car how you want and no one can say it's "wrong"!
I'm sure all repo tags will look "wrong", though.
I'm gonna go against the grain here and say if you want a tag, get one. WITH a caveat...
If your car is fairly plain/common - 383 auto nonHi impact colour nothing odd etc, then get one made to reflect what the build sheet [and Chrysler Historical paperwork if you can get it] shows and whats on the car that you think is original.
If the car is a lime green Hemi 4 speed post car, I'd be careful doing that because it immediately makes folks think that youre trying to pull something and will probably actually hurt you when you go to sell it.
I know if my ol car didnt have one, I would want one. Of course, no one would ever think about me trying to fake a 318/auto Belvedere either! :)
